App for Watts Vision
Dear,
Are there any developers currently working on an app for the Watts Vision heating solution? I can’t find anything on it yet.
This is the system I’m referring to:
https://www.watts-klimaatregeling.nl/NL/watts-vision-systeem-868-mhz/watts-vision-systeem-868-mhz
thanks,
Niels V
Hi Niels,
did you already put this request in the central App Request topic? I’m gathering information about this product as I’m about to purchase is. Homey support will even make this better of course :slight_smile:
Not yet, I die contact the producer of Watts Vision. But so far no reply yet as they were closed during the holidays.
Did you find a solution to control your watts heating via Homey?
Nope, and what I understood it can’t be done without extra hardware, as the broadcasting signals don’t match
Any progress? Watts is a great working system. Maybe it is possible to make an api communicating with watts vision wifi-controls web app? Like many others. Really hope someone can make a Homey app.
Hoi iemand watts vision werkend? Radiatoren en vloerverwarming, thermostaat?
Hi, does anyone have watts vision working? Radiators and underfloor heating, thermostat?
moving this one to an existing thread, App for Watts Vision
but if you want a community developer to create an app:
Use this Topic, use the Template, add all necessary information…
Nog nieuws hierover?
It’s possible, there already is an integration for Home Assistant. I started working on it and i think i understand how the API works. But i’m not making any promises because i am just a amateur and i have never made something for the Homey so i am trying to figure it out.
I will start on only reading the thermostat’s value, after that we will see.
!! I have no idea if this is going to work and if so when it will be done !!
Correction: This would only work if you can access your system via the app or internet(Watts Vision)
Hallo,
Het is mogenlijk, er is al een intergratie voor Home Assistant. Ik ben er mee begonnen, voor het grootste deel snap ik nu hoe de API in elkaar zit. Maar ik beloof niks, ik doe dit voor de hobby en ik heb nog nooit wat gemaakt voor Homey dus ik moet alles nog uitzoeken.
Ik ga proberen om in eerste instantie alleen de thermostaaten uit te lezen, vanaf daar kijk ik verder.
!! Ik heb nog geen idee of het gaat lukken en wanneer dat dan zou zijn !!
Correctie: Dit zou alleen werken als je je systeem kunt gebruiken via de app of het internet(Watts Vision)
Interessant! Ik heb hier ook nog een PI liggen met HA erop. Heb je wellicht een URL naar de Home Assistant integratie? Kan ik wellicht meekijken?
oh wacht. ik heb (nog) geen Watts Vision.
De installateur heeft alleen die RF868 kast opgehangen en een paar RF-themrostaten neergezet.
Kan je dus niet direct helpen. Moet ik eerst zo’n Vision aanschaffen.
@Lampje
Hello Lampje,
Are you making any progress already? I also have the Watts Vison system and am definitely interested in the app. I can’t help you with developing it, but if you can use a tester I am available.
Regards, Ton
Hello Ton,
I made some progress, but at this moment i’m a bit busy with school so the project is on hold for a couple of weeks. When i need testers i will send you a message.
Hoi Ton,
Ik heb wat voortgang geboekt, maar op het moment ben ik druk met school dus het project ligt even stil voor een paar weken. Wanneer ik aan het testen toe ben hoor je van mij.
al voortgang?
Hi Lampje,
Any progress yet? Hope so because I am also very interested in reading out the Watts Vision Thermostats into Honey? You need any help?
Regards, Ingmar
Hi Lampje,
Any progress. Are you still planning to develop the Watts Vision app?
Regards, Ton
Though I know this topic is very old, is there anything going on with Watts Vision support for Homey?
I am using watts vision on home assistant and with the home assistant community app in homey i can control all the sensors and settings, i can change the temperature and modus. Everything workd perfect
Kan je dan vanuit google home een verbinding maken met homey. Want inderdaad ik heb nu koppeling met google home.
