New app update (test: 2.11.9):
Changes:
- FIX: Flowcards for multiple device with single Hub at the same time
- FIX: Flowcards for multiple standalone devices at the same time.
- FIX: refresh P2P service when expired. fixes unresponsive devices
So in release 2.11.1 I fixed the following bugs:
- [BUG] multiple flowcards at once are not working without delay
- [BUG] triggering multiple cameras with different Hubs at the same time doesn’t work without delay
But with that release introduced this one:
- [BUG] triggering multiple cameras with same Hub doesn’t work anymore
@CyberSponk Can you test if your flow works again? So all 4 camera’s at the same time.
@Chris_nl Can you maybe also test as you have multiple stand-alone devices?
I already tested with 1 Homebase device and 1 Standalone device and that still works. Also multiple cards at the same time is not an issue.
