Yes, no problem, thanks a lot for your help.
Have a nice holiday
Hello @Adrian_Rockall
First I want to say: have a great holiday
I have find my problem, I had to select something else and that work. A lot of work to select the correct one but no problem. Iām happy that is have find it by myself
Thank you, have a great Holiday
If the device you are looking for is the āGrande porteā then try the āOpen / Close Remoteā / āOuvrir / Fermer TĆ©lĆ©commandeā.
If thatās not the one then let me know the name it has been given in Tahoma.
Try the āRoller shutter (io)ā
Thanks a lot for your help, yes itās āGrande porteā and itās good with the āOpen / Close Remoteā
There is just a strange behavior, when I press the button the door open so itās good but if I want to press the button again to stop it or close it, the button no longer works for several seconds and I have to wait to be able to close it.
Thanks this worked and my 3 ZigBee blinds were detected but I think the device position info may be inverted as a closed blind has a value of 0% and open blind shows a position of 100%. Also the window covering state value is missing i.e. I am guessing this should show Open or Closed?
There should be an option in the Advanced settings to invert the position.
Athom donāt like having both position and open/close. Just use the position value to determine if itās open or not.
