RTS can’t tell you what position they are in as the only receive open / close / stop commands and return nothing. Homey can indeed control RTS directly, but range might be an issue.
If you want exact position control and reporting then you need IO motors and Tahoma.
Hey all new to Homey and have a Tahoma Switch which I’m trying to get to report my ZigBee blinds. wanted to see if there are any other tips/trick I’m missing or if the new Tahoma Switch is even supported.
OK, the device type isn’t currently supported by my app but it looks like I can add it. It has the standard commands for open, close and set position but I’m not sure about getting the position.
Could you enable the Information Log and then control the blind via your Switch and once it has finished moving, send the log.
@Adrian_Rockall most recent Device log ID: -379755711 as well as I sent an Event Log with the roller shade extending fully (closed) returning to fully open and the favorites setting. Let me know if there is any other information you need.
I noticed that the sensors no longer transmit their data in a timely manner.
My window sensor shows open on Somy and only seconds later on Homey.
Can I set the query time?
If you have a Tahoma and have enabled developer mode, the app polls for events every three seconds else it polls every 30 seconds, which is the limit agreed with Somfy. Any faster, apart from short bursts and they will block your account.
