[APP][Cloud & Pro] Somfy Tahoma & Connexoon (v4.0.106, test v4.0.122)
Yes. Once the developer mode is enabled on your Somfy account, the Tahoma box broadcasts it’s details via mdns. Once the app detects the box it connects to and will use it for all supported devices. Some things still only work via the internet, but Io / RTS and even zwave or ZigBee devices if you box has those will all be local.
If you look in the Configure App pages there is a tab for Local Tokens, and if you tap on Get Tokens it will display a list of tokens that have been generated for local access. No need to do that though but just a confirmation that it is working.
Also, if you select the Device Log tab and then hit Get Log, the list will show all the devices in the cloud local and local groups.
