All of a sudden all my xiaomi devices are not working anymore (except my door sensor). I have battery powered switches (3), cube, temp, humidity sensor (displays -100) and 3 powered plugs. I have reset homey, pulled the plug for a couple off minutes, updated to the latest rc. Nothing. Zigbee is working because I also have an ikea plug and that one is working just fine.
Does anyone know what could have happened and what can be done to make it work again?
Greetings,
Aaron
aaaaand, now it works again after doing exactly nothing…
Yesterday before I went to bed a switch worked one time and then it stopped again. This morning when I woke up, everything worked like nothing happened.
Strange!
Greetings,
Aaron
Dayli restart is what I do
@erik.fisher working on finding a solution to add support for the B1 curtain controller.
Unfortunately (for me), it requires more then just a minor modification of the Xiaomi curtain controller.
The B1 curtain controller doesn’t report the available Zigbee clusters and commands; which Homey expects / requires. There are options to work around this, but that will require quite some workarounds… I’ll keep you guys updated.
For some reasons, the Zigbee controller is stalling when you do a PTP, which will result in no Zigbee devices available. A reboot as suggested by @Erik_M_Madsen will solve the issue (in most cases).
I see - thanks for the detailed update! Appreciate it. You are doing Gods work🙌 Let me know if I can be of assistance!
Erik
Hit @TedTolboom and @Erik_M_Madsen, I did do a restart and that dit not work either. Not immediately that is, the next day everything was fine. I can’t say if that was because of the restart.
thanks for your advice though.
Greetings,
Aaron
Are you guys also crazy about the Xiaomi Opple scene selectors? The are Cool! And I want them.
Buying them is not the point, i did already.
Adding them to Homey is the thing.
For that we need to give support to Ted, then he can buy them and work on it.
The buttons do look nice! You could just donate one of yours or donate 15 EUR so he can buy them. Then there is still a matter of having time and even the zigbee rewrite, if the current zigbee implementation doesn’t support them… then Ted cannot help it.
Does anyone know how I reset a Xiaomi double relay ( LLKZMK11LM)?
I had it paired to the Xiaomi gateway but would like it paired to Homey. Unfortunately I don’t have access to the gateway anymore, so I need to reset the hard reset the relay.
Thanks!
Follow the manual when adding the relay to homey push the button 5 seconds
Simple! Thanks!
It finally works.
I had to try 5 different places for the device into the fridge, but now it is already working for 3 days. So I quess this wil work :sunglasses:
The battery did stuck on 63% after about a week.
So thanks for the information
Hello buddy developer, is it possible to make the flood sensor xiaomi available? Thank you
Sorry, but I’m French and it would be too long for me to read post by post, can you give me a summary please
Sure.
Hey guys - having a little issue with an Aqara switch - I have a 1x and a 2x scene, one to toggle a light (1x) and one to set a dim level (2x) or not depending on the dim value
However, I’d say there’s a 50-50 chance of my light going off (almost as if it’s reacting to the 1x too quickly) - is there anything I can do to correct for this?
Just received, now connecting with Homey :wink:
@TedTolboom
So, I think I reached the limit or something. I have 24 devices at the moment including 2 inner powered wall plugs. So according to the 20 sensors per zigbee router “rule” I should be able to connect 60 devices. Sadly Homey won’t accept extra devices anymore. If I try to add a device like Aqara temperature sensor, a door sensor it times out. (never had this problem before). Even extra Inner SP120 plugs won’t add to the network anymore. After some searching it seems like I’m not the only one with this problem, but I’ve also read post with users with more than 70 devices.
I’ve tried, restarting. PTP (20 minutes wait) restarting… Close to the Homey initializing… nothing seems to do the trick. The only thing I did not try is rebuilding the Zigbee network. This will damage so much flows if I all need to fix them. Any idea’s?
Hi @TedTolboom,
I’ve managed to get the Aqara B1 Curtain Controller to work. I use this to set the curtain position:
this.node.endpoints[0].clusters.genAnalogOutput.write(0x0055, value); // Value is 0-100.
I can give you the full source tonight if you like, just let me know!
Cheers,
Paul
