Nice, it worked for me!
Friends reminder of the external temp e1 issue… The external temp control Funktion is online since Several weeks now but its useless until the issue is not fixed! The e1 reverts all the time Back to internal… Please please fix this!
Hey! No, still no luck. Kind of suprised that no one else has replied. Haven’t really tried anything since I posted this. Tried every combination of resetting, readding, trying different versions before I posted here. I have another sensor, but I don’t want to open it before I get the first one to work. It might be that I have a faulty one? Maybe I should try with the second one?
I thought the same, but I have tried with two different. And also read here that other people have problems. But I’m really mad that they don’t respond to my support case
Can anyone comfirm this? I have the same issue and have the Homey Pro (2016 - 2019)
Hey, just checking if anyone has an experience with lock U50 or U100. If it’s supported and if it is, what can I do trough the homey app.
Same issue but with the T1 Water leak sensors on HP2019.
Thank you so much for adding support for the Dual relay module T2.
It seems that the Dual relay module T2 does not respect the pulse function properly. I have not yet checked if it actually gives a puse or is “on or off”, but it seems to function as on/off when pressing “power” button in the device controls.
I hope this can be adressed for my flows to be correct when using this device as a garagedoor opener/trigger.
Does this app supports the aqara smoke sensor. With all his functions? Temperature, put it off and connect the other smoke sensors to pull on the alarm
Hey, my P1 sensor ir like, 95% reliable. Almost always it turns on when I walk in my kitchen. But at least once every few days I will walk and the sensor will trigger when I’m at the middle of my kitchen or take up to 20 seconds to trigger.
Anyone having the same experience? There is a fix? Didn’t fiddle with configurations if it matters
Hello, I am also testing it, and it seems when you put it on default mode(wet contact) then it acts as a real on/off switch. if you select any of the 2 dry contact modes(either pulse or on/off) then it does pulse behaviour in both cases! So I think as long as you don’t do the jumper cable between Lin and Lout that you can use it as dry contact while setting the device mode (wrongly) to default wet contact mode. Or is that unsafe?
Best regards,
I am not familiar with the risk of using wet mode in a dry setup, but I would love it to be able to work as “on or off” in dry mode as it intended.
I am more also concerned about the switch being reported as on or off, rather than just “off” after a pulse have been sent in pulse mode.
Hi everyone!
I have Aqara T1 door and window sensors installed on all my windows - is there anyway of changing the status to show windows are open / closed rather than contact alarm on / off?
Home Assistant shows the sensors as window open / closed which is far more easier for the family to understand.
Hello all,
Has anyone had any success with the H2 light switches? It seems they’re not currently supported in the Homey app. I have the switch working over Matter but I’d like to use the programable button functions.
I had hoped the Homey would act as a hub for Aqara allowing use of the native app but it seems you’d need to use an Aqara specific hub.
Hello Ted, i wrote already PM and several posts here … please fix the E1 External temp issue … it is NOT usable in this state … this is NO NEW request this is a request to fix the broken one you implemented several weeks ago… please reply if you already work on it or when u are able to to look at it.
many thanks
I just bought an E1 thermostat.
It my fist Aqara unit.
I can add it to Homey, I can make a flow that adjust the Manual/Away/off mode.
I can enable/disable child lock.
BUT Im not able to adjust the temp.
Any idea what might be wrong here?
Thanks!
What Flow card do you use?
Hello, I would be very grateful if you could add support for a valve that closes the water flow when a leak is detected. “Aqara Valve Controller T1” to the Aqara application. Best regards
Hi, wondering if there’s any support for camera’s like the Aqara E1 camera?
