No.
It pulls approx 3A continuously according to my shelly measurements. Only in Homey it jumps.
Btw it never reaches the termostats threshold since its set too high.
No.
Then you’ll need to send me an app diagnostics report…
not seeing the energy level for H1 switches. Is this a known issue?
2c125460-9ded-4b91-a3ec-f7b124280287
The diagnostics log only has a finite amount of data, in this case showing a 20 minutes period (filtered for your switch device).
At 6:00 the switch is turned off (by Homey), after which a power value of 0 is reported (obviously). Can you send a report where the switch is on for about an hour?
2024-01-23T05:57:10.927Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] handle report (cluster: electricalMeasurement, capability: measure_power), raw payload: { activePower: 0 }
2024-01-23T05:57:10.928Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T06:00:01.580Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report {
state: true,
consumption: 30.196142196655273,
power: 538.4874267578125
2024-01-23T06:00:01.581Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: meter_power), parsed payload: 30.196142196655273
2024-01-23T06:00:01.581Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 538.4874267578125
2024-01-23T06:00:26.901Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] set onoff → false (cluster: onOff, endpoint: 1)
2024-01-23T06:00:26.902Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] set onoff → false (command: setOff, cluster: onOff, endpoint: 1), parsed payload: {}
2024-01-23T06:00:27.148Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] handle report (cluster: onOff, capability: onoff), raw payload: { onOff: false }
2024-01-23T06:00:27.148Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: onOff, capability: onoff), parsed payload: false
2024-01-23T06:00:27.593Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: analogInput, endpoint: 21, capability: measure_power), parsed payload: 0
2024-01-23T06:02:09.885Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] handle report (cluster: electricalMeasurement, capability: measure_power), raw payload: { activePower: 0 }
2024-01-23T06:02:09.885Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T06:05:50.337Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report { state: false, consumption: 30.199867248535156, power: 0 }
2024-01-23T06:05:50.338Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: meter_power), parsed payload: 30.199867248535156
2024-01-23T06:05:50.338Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 0
2024-01-23T06:07:08.861Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] handle report (cluster: electricalMeasurement, capability: measure_power), raw payload: { activePower: 0 }
2024-01-23T06:07:08.862Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T06:11:36.718Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report { state: false, consumption: 30.199867248535156, power: 0 }
2024-01-23T06:11:36.718Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: meter_power), parsed payload: 30.199867248535156
2024-01-23T06:11:36.719Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 0
2024-01-23T06:12:07.855Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] handle report (cluster: electricalMeasurement, capability: measure_power), raw payload: { activePower: 0 }
2024-01-23T06:12:07.856Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T06:17:06.862Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] [dbg] handle report (cluster: electricalMeasurement, capability: measure_power), raw payload: { activePower: 0 }
2024-01-23T06:17:06.863Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T06:17:21.702Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report { state: false, consumption: 30.199867248535156, power: 0 }
2024-01-23T06:17:21.703Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: meter_power), parsed payload: 30.199867248535156
2024-01-23T06:17:21.703Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 0
I will manually runt if for one hour now and then send it again ![]()
Update 1.7.7 fixed the problem. Thanks
I can confirm it is working again with 1.7.7.
Thanks a lot @TedTolboom
Thanks, that helped… and you are right
The device is reporting the power consumption through 2 different communication lines. Through the Zigbee standard power reporting; activePower attribute out of the electricalMeasurement cluster and through the aqaraLifeline attribute out of the Aqara manufacturing specific cluster.
It shows the the power is correctly reported through the aqaraLifeline attribute, but the zigbee standard reporting continuously reports 0 W.
In the next 1.8.x release I will disable the zigbee standard reporting for this device, which should fix this issue.
2024-01-23T08:50:40.436Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report {
state: true,
consumption: 30.48052978515625,
power: 532.6475219726562
2024-01-23T08:50:40.437Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 532.6475219726562
2024-01-23T08:51:36.946Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T08:56:11.863Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report {
state: true,
consumption: 30.53003692626953,
power: 535.4004516601562
2024-01-23T08:56:11.865Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 535.4004516601562
2024-01-23T08:56:35.924Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T09:01:34.912Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T09:01:54.116Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report {
state: true,
consumption: 30.581411361694336,
power: 537.826416015625
2024-01-23T09:01:54.117Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 537.826416015625
2024-01-23T09:06:33.880Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T09:07:40.991Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report { state: true, consumption: 30.633384704589844, power: 539.189453125 }
2024-01-23T09:07:40.992Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 539.189453125
2024-01-23T09:11:32.863Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: electricalMeasurement, capability: measure_power), parsed payload: 0
2024-01-23T09:13:21.053Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] lifeline attribute report { state: true, consumption: 30.68436622619629, power: 534.8681640625 }
2024-01-23T09:13:21.054Z [log] [ManagerDrivers] [Driver:switch.n0agl1] [Device:f2b338a8-2eb0-4efe-9af5-0945d908a66c] handle report (cluster: aqaraLifeline, capability: measure_power), parsed payload: 534.8681640625
hello,
I’ve question about aqara fp2, is it add to homey pro ?
Thx
Hi, just bought an Aqara E1 double switch, thought it would be supported but it isn’t. The ModelID is lumi.remote.acn004, the interview is mentioned previously on this page last august. Can this device please be added?
Thanks for maintaining the app
Hi again. Do you have any info regarding my issue with the H1 Switch not reporting energy consumption? Did you get the interview result I sent you on DM?
Looking into it for the next 1.8.x update.
Anybody an idea about my question above?
I tested this app but never find any device; I checked the Log, all devices are listed… maybe I missed something?
Thanks!
Maybe, but this isn’t the correct thread to post your questions in for that particular app, or for that device (which isn’t a Zigbee device).
One thing to note is that your device has to be decoupled from the iOS Home app before you can use it with the HomeKit Controller app.
Please bring 1.9.0 before winter its gone ![]()
