Which Homey model? Which firmware version? Did you read Ted’s post about which versions it supports?
Homey Pro early 2019, FW 10.0.5…
So you didn’t read Ted’s post…
Seriously…?
Let me quote Robert’s post:
The information from TED about the E1 thermostat is less than 24 hours old!
Guys, please use the search first before you post superfluous questions.
have another question: how do I get Wall Switch H1 Single (With Neutral) to show power meter in Homey? Found nothing searching for this device in here…
If it doesn’t show measured power, please send me:
  1. An app diagnostics report: settings > apps > Aqara > send diagnostics report (with mentioning the issue, in English please)
  2. The interview results from the interview of the switch at (Zigbee tools) in this topic or through an DM
d9e541bb-5465-45f6-9e73-7db83c6b1e39
This device doesn’t show measured power.
“node”:{
4 items
“modelId”:
string"lumi.switch.n1aeu1"
“manufacturerName”:
string"LUMI"
“endpointDescriptors”:[
2 items
“endpoints”:{
2 items
@Stig_Solberg Thanks. I need to check the content of the “endpoints” and “endpointDescriptors”… can you share that (as well)?
Thank you, Ted :slight_smile: Door sensors T1 and Water leaks sensors T1 finally work! Great job! It made my day :slight_smile:
How much of that do you need?
All of the interview and share it using </>
Hello, is it possible to have compatibility of this product with the app?
2023 Aqara Licht Sensor T1 (GZCGQ11LM)
Thanks a lot!
"ids": {
    "modelId": "lumi.sen_ill.agl01",
    "manufacturerName": "LUMI"
  "endpoints": {
    "ieeeAddress": "54:ef:44:10:00:85:be:73",
    "manufacturerName": "LUMI",
    "swBuildId": "2019",
    "capabilities": {
      "type": "Buffer",
      "data": [
        132
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 26863,
        "_reserved": 18,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 262,
        "_reserved1": 1,
        "inputClusters": [
          0,
          1024,
          3,
          1
        "outputClusters": [
          3
    "touchlinkGroupIds": [],
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "name": "appVersion",
                "value": 27
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackVersion",
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "name": "manufacturerName",
                "value": "LUMI"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "value": "lumi.sen_ill.agl01"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powerSource",
                "value": "battery"
                "acl": [
                  "readable"
                "id": 8,
                "name": "appProfileVersion",
                "value": 255
                "acl": [
                  "readable"
                "id": 9
                "acl": [
                  "readable"
                "id": 10
                "acl": [
                  "readable"
                "id": 11
                "acl": [
                  "readable"
                "id": 16384,
                "name": "swBuildId",
                "value": "2019"
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 1
            "commandsGenerated": [],
            "commandsReceived": [
              "factoryReset"
          "illuminanceMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "measuredValue",
                "value": 13425,
                "reportingConfiguration": {
                  "direction": "reported",
                  "attributeDataType": 33,
                  "minInterval": 3,
                  "maxInterval": 3600,
                  "minChange": 15,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 1,
                "name": "minMeasuredValue",
                "value": 1
                "acl": [
                  "readable"
                "id": 2,
                "name": "maxMeasuredValue",
                "value": 50000
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "tolerance",
                "value": 0,
                  "status": "UNREPORTABLE_ATTRIBUTE",
                "acl": [
                  "readable"
                "id": 4,
                "name": "lightSensorType",
                "value": "cmos"
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
            "commandsReceived": []
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0,
                "name": "identifyTime",
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "identifyQuery.response"
              "identify",
              "identifyQuery",
              "triggerEffect"
          "powerConfiguration": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "name": "batteryVoltage",
                "value": 34
                "acl": [
                  "readable",
                  "writable"
                "id": 49,
                "name": "batterySize",
                "value": "CR2"
                "acl": [
                  "readable",
                  "writable"
                "id": 51,
                "name": "batteryQuantity",
                "value": 1
                "acl": [
                  "readable",
                  "writable"
                "id": 52,
                "name": "batteryRatedVoltage",
                "value": 30
                "acl": [
                  "readable",
                  "writable"
                "id": 53
                "acl": [
                  "readable",
                  "writable"
                "id": 54,
                "name": "batteryVoltageMinThreshold",
                "value": 27
                "acl": [
                  "readable",
                  "reportable"
                "id": 62,
                "name": "batteryAlarmState",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0,
                    0,
                    0,
                    0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0,
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "identify",
              "identifyQuery",
              "triggerEffect"
I just installed the test version and the T1 temp and humidity sensor works great.
Thank you @TedTolboom for a great start of the day and for all the work you put in to make smart homes accessible to us less smart people!
Thank you so much, Ted! I am very much looking forward to the E1 thermostat support!
How is the user experience with the new T1 sensors? Particular the door/window- and watersensor?
Especially regarding Zigbee range?
I have a mailbox that I would like to monitor, but the current door/window sensor is very much at the edge of what my setup/distance can handle.
Unfortunately I can not put any routers in between because I am in an apartment building.
Sent you a DM. Thanks!
I can confirm that my T1 Temperature and humidity sensors are now WORKING with the new Aqara v1.8.0 app :smiley::ok_hand:
Thanks a lot for your work!
Is there some way to make sensors report values to Homey at a specific time interval? (or more frequently). Sometimes my sensors updates in 5 minutes and sometimes in 60 minutes (not only T1 sensors).
