Who comes up with that? After adding it, it will be used near the homey. 2 walls and heater are between where it was added (coincidentally actually) and where it is deployed. And there are other devices in the living room, why didn’t they find the device?
Basically, 15 devices isn’t really that much. Even with our 3 rooms, kitchen, bathroom, we have far more SmartHome devices (whereby ZigBee a little more and WiFi a little less) Alone via Tuja-Cloud there are already almost 15 WiFi devices, plus the Google parts (Chromecast, Hub, Mini) the LED lamps from HUE, etc., 15 is very, very tight, isn’t it?
Athom?
Homey Pro can handle up to 15 direct ‘children’. These are either routers or end devices that are connected directly to Homey.
This does not mean, however, that you can only connect 15 Zigbee devices in total to Homey Pro: devices can also be connected to Homey indirectly, via routers that relay the commands.
“a limited number of directly connected Zigbee devices”
This doesn’t apply to WiFi devices or Zigbee devices that are managed by other hubs.
@TedTolboom FP1 presence sensor received - please let me know when you need testing in the field.
Roger
Hi @TedTolboom are you currently working on support for the Roller Shade Driver E1?
I received the FP1 just now. Would be great to add it. As it (hopefully) will significantly change the Dominica space. (Yes I have high hopes).
Attached the interview data
  "ids": {
    "modelId": "lumi.motion.ac01",
    "manufacturerName": ""
  "endpoints": {
    "endpointDescriptors": [
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 65520,
        "_reserved1": 0,
        "inputClusters": [
          0,
          3,
          64704
        "outputClusters": [
          3,
          25
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "name": "appVersion",
                "value": 54
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackVersion",
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "name": "manufacturerName",
                "value": "aqara"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "value": "lumi.motion.ac01"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode",
                "value": "20210121"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powerSource",
                "value": "dc"
                "acl": [
                  "readable"
                "id": 13
            "commandsGenerated": [],
            "commandsReceived": [
              "factoryReset"
          "identify": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
              0
        "bindings": {
          "identify": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
              0
          "ota": {}
Hello @tedtolboom
Will the aqara curtain Driver E1 supported for homey??
Greetz François
Yesss i’m interested too👍
Can you add Aqara Zigbee termostat?
@TedTolboom waiting patience for the aqara E1 curtain Driver :blush: thanks for the good work so far :muscle::birthday:
I think you accidentally typed “patient” in your sentence…
It was meant to be a bit sarcastic. Patient was the right word, but you are not patient at all imho…
Hi, will the Aqara H1 Wireless Single Switch be supported anytime soon? Or can you use the Aqara H1 Wireless Switch Double for the singe switch as well?
??? I’m patience, good things you don’t want to rush😉
i have ordered an aqara smoke detector, when i connect it it says "cannot find installed app the device is connected as unknown zigbee device’
Can you help?
Also looking for the same device support :slight_smile:
Big thanks to all devs that enables this!
Any news to when an update will come? Refreshing the test app page every day last month :grin:.
If there is anything we can do to help just say so! Donated a few coins a month ago, if more is needed for this update to come I’m sure we all can help more!
On wall plug set as type ”light”, I can not change status indicator.
It states: ”Status indicator not configurable”
I want to show ”Power”, even on devices used for light. There’s plenty of space available in the icon to display both power and the light indicator. Extra important now when we all are trying to cut power consumption. Please add this as a feature request.
(I have asked Athom and they responded that this is a limitation in your app, not in Homey)
easy said, but there is no rollercurtain motor apart from the Aqara one.
@TedTolboom I have an aqara m2 bridge. I add the motion sensor en saw in settings that is was possible tot change the motion sensor sensitivity. Could you add this function? En alsow saw check the settings of the wall switch d1 end I saw that you could let is function as a wireless switch could you add this function 2 thx!
I can’t find the M2 in the list of supported devices in this topic
