I still have the same issue.
Aeotec says I need to changes settings…
Is there any way to do this in Homey? I tried to go to the device and select “Advanced Settings” Here I don’t see a match.
Below is what I received from Aeotec what should solve the issue…
Parameter 91 - 93 (Threshold values) to 0 or the highest number that they can be.
Then configure Parameter 101 (automatic sensor reports) to report all sensors.
Then you can use Parameter 111 (time of sensor reports set in seconds) to determine how often the switch reports.
However I did find Aeotec Home Energy Meter Gen5 - Settings - #7 by Rohman
but…
It should be easy and understandable to change a simple setting if that is required…
It should work fine after a factory reset…
I selected this device because of Homey. It came up in the list of “supported” devices working with “Z-Wave”
