API Endpoint Presence didn´t work
Hey,
Why can’t I retrieve any data at the Presence endpoint (→ ManagerPresence - Homey Web API)? Everything else works fine.
Maybe you should share or point to the code you use for it?
Otherwise I’m afraid you won’t get any sensible reply :wink:
“Code or it didn’t happen”
this work:
	$curl = curl_init();
	curl_setopt_array($curl, array(
	  CURLOPT_URL => $remote_url . '/api/manager/devices/device',
	  CURLOPT_RETURNTRANSFER => true,
	  CURLOPT_ENCODING => '',
	  CURLOPT_MAXREDIRS => 10,
	  CURLOPT_TIMEOUT => 0,
	  CURLOPT_FOLLOWLOCATION => true,
	  CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
	  CURLOPT_CUSTOMREQUEST => 'GET',
	  CURLOPT_HTTPHEADER => array('Authorization: Bearer ' . $homey_api_data['api_key'], 'accept: application/json'),
	$response = curl_exec($curl);
	curl_close($curl);
	print_r(json_decode($response, true));
and this, for presence not:
	  CURLOPT_URL => $remote_url . '/api/manager/presence/state',
	curl_close($curl);
only the URL is an other one
the output of this request is empty
And now?
