Hello everyone
First of all, sorry that things have been a bit quiet from my side for a while. Iâve continued to follow your feedback and the discussions here, but unfortunately I havenât had the time to reply to everything individually.
Iâve now released a new test version 0.7.5 of the Anker SOLIX app.
Over the past few months, there has been quite a bit of feedback regarding different devices, smart meters, control options/Flow Cards, and especially newer SOLIX systems. With this new version, several things have been changed, improved, and extended.
Important Country/Region Settings
The country/region settings can now be configured directly in Homey under:
Settings â Apps â Anker Solix
Please make sure that the correct country/region is selected there.
I also recommend removing and re-adding your Anker SOLIX devices after updating to version 0.7.5. This helps ensure that the devices are initialized with the new settings and rules out issues caused by configurations from previous versions.
Especially when reporting an issue with 0.7.5, please re-add the affected device first so we can exclude old device configurations as the cause.
Iâd really appreciate it if you could test the new version with your systems, especially if you experienced issues with previous versions.
If something still isnât working, please include as much of the following information as possible:
which Anker SOLIX model you are using
which country/region is selected in the Anker Solix app settings
which smart meter or other accessories you have
which Homey model you are using
what exactly isnât working
and, in case of errors, a diagnostic report would be very helpful
Feedback that something is now working correctly is also very helpful!
Please keep in mind that this is still a test version, so there may still be some bugs.
A big thank you to everyone who has tested the app so far, reported bugs, provided device information, or otherwise contributed to its development!
Best regards,
Til
German Version
Hallo zusammen
erst einmal sorry, dass es hier von meiner Seite etwas lĂ€nger ruhig war. Ich habe die RĂŒckmeldungen und Diskussionen weiterhin verfolgt, bin aber leider nicht dazu gekommen, auf alles einzeln zu antworten.
Ich habe jetzt eine neue Testversion 0.7.5 der Anker SOLIX App veröffentlicht.
In den letzten Monaten gab es hier einiges an Feedback zu verschiedenen GerÀten, Smart Meter, Steuerungsmöglichkeiten/Flow-Karten und insbesondere auch zu neueren SOLIX-Systemen. Mit der neuen Version hat sich einiges geÀndert bzw. wurde erweitert.
Anker Solix | Homey
Wichtig LĂ€nder-/Regionseinstellungen
Die LÀnder-/Regionseinstellungen können jetzt direkt in Homey unter folgendem Pfad vorgenommen werden:
Einstellungen â Apps â Anker Solix
Bitte stellt sicher, dass dort das richtige Land bzw. die richtige Region ausgewÀhlt ist.
Ich empfehle auĂerdem, nach dem Update auf Version 0.7.5 die Anker SOLIX GerĂ€te zu entfernen und erneut hinzuzufĂŒgen. Dadurch wird sichergestellt, dass die GerĂ€te mit den neuen Einstellungen initialisiert werden und mögliche Probleme durch Konfigurationen aus Ă€lteren Versionen ausgeschlossen werden können.
Insbesondere bevor ihr einen Fehler mit Version 0.7.5 meldet, fĂŒgt das betroffene GerĂ€t bitte einmal neu hinzu. So können wir alte GerĂ€tekonfigurationen als Fehlerursache ausschlieĂen.
Ich wĂŒrde mich daher sehr freuen, wenn ihr die neue Version einmal mit euren Systemen testen könntet, insbesondere diejenigen, bei denen es mit den vorherigen Versionen Probleme gab.
Falls weiterhin etwas nicht funktioniert, schreibt bitte möglichst dazu:
welches Anker SOLIX Modell ihr verwendet
welches Land bzw. welche Region in den Anker Solix App-Einstellungen ausgewÀhlt ist
welches Smart Meter bzw. weiteres Zubehör vorhanden ist
welches Homey Modell ihr nutzt
was genau nicht funktioniert
bei Fehlern gerne auch einen Diagnosebericht
Auch RĂŒckmeldungen, dass etwas jetzt funktioniert, sind sehr hilfreich.
Da es weiterhin eine Testversion ist, können natĂŒrlich noch Fehler auftreten.
Vielen Dank an alle, die bisher getestet, Fehler gemeldet, GerÀteinformationen geliefert oder sich anderweitig an der Entwicklung beteiligt haben!
Viele GrĂŒĂe
Til
