Analysis of Homey Pro 2023 RESTART LOOP Failure On Two Hubs
I got my hub repaired and returned to service last night, after being down for almost 3 days. And, what I learned is IMPORTANT evidence to the nature of this problem. I have purchased two HP23, and both have failed after experiencing the same problem. With the first hub, I manually added every one of the approximately 200 devices, which included crawling around under the house, in the attic, the outdoor shed, and so forth. I was very happy after the first hub was established and coded, and it was running smoothly, with great performance, and no indication of problems. Then one morning, after a reboot for an automatically installed firmware update (it’s a bad idea to allow auto updates), it failed, and went into an unending reboot cycle. I tried factory reset with restore of a cloud backup, factory reset with a local backup, and dozens of other options, but nothing worked. I could factory reset the hub and do a setup but any attempt to use a backup caused the restart loop to continue. I worked with technical support, but they never reached a solution and my patience was limited after a week of trying to recover.
This experience led me to believe that my user data had somehow damaged the firmware/storage environment. With no other options for recovery, I purchased a second HP23, and to avoid potentially damaging it with my suspect user data, I manually reinstalled every single device, replaced old devices with new ones, and once again completed a lengthy setup and coding process. The result was excellent, with no indications of a potential issue. I had faithfully created frequent PC backups during the setup of this second HP23, but didn’t expect the issue to return. Then last Friday morning, after doing a routine local backup to my PC, the restart loop started again.
I tried MANY different recovery techniques that I had learned during the previous experience, and this second HP23 behaved EXACTLY as the first HP23. Yes, I could factory reset it, but no cloud or local backup could be restored; not even a very old backup. I was extremely disappointed after spending hundreds of hours setting up my smart home, and failing twice.
However, I formulated some theories on what had happened and how to test those theories. Those theories included the idea that (a) the CM4 module where the processor and memory live were defective, OR (b) the factory reset process is NOT actually returning the storage to an original state and/or corrupting the file system. Both of these theories could be tested by replacing the CM4 module with a new module and restoring a local backup that was taken AFTER the failure. That was my solution, and that brought my system online. Everything is running smoothly, no evidence of a user data problem.
Now, I am happy to be back online, but I don’t feel safe about whether or not this issue will return. If it was a faulty CM4 module, then there are hubs that need to have the CM4 replaced before failure, and we need to know which hubs will fail based on the modules that were used. If it is a bug in the firmware or firmware reset code, then it needs to be found quickly. I lean towards this issue being a firmware/reset coding issue. I hope the development team will do something that the end-users cannot do, investigate the logs, the files, and the partitions on a failed CM4 module and diagnose the root cause of the problem. I believe a software engineer would likely see the issue in plain sight within a few minutes of research.
I have offered my two failed CM4 modules to the development team, and hopefully they will accept my offer and research the problem. I believe they can easily plug the module into an IO board or another homey pro to study the issue. I still believe HP23 is the BEST smarthome option by far compared to other sophisticated smart home platforms, but this failure mode has the potential to impact developer acceptance.
FINAL UPDATE: Both of my HP 2023 hubs are back online and working great so far. Both hubs were repaired by installing a new CM4 module. One was repaired with a 8/32 GB module and the other one with a 4/16 GB module. I made no effort (so far) to expand the eMMC partition size; it remains at the original 8 GB. The hub automatically recognizes additional memory and appears to utilize it. The HP 2023 shipped with a 2/8 GB module, and this may be the heart of the problem where more advanced users are pushing the 2 GB memory limit, making the hub more susceptiable to various failure modes. I see today that a “new” hub is shipping, the HP 2026. There is only ONE difference between the HP 2023 and the HP 2026, 4 versus 2 GB of memory. If you have the HP 2023, purchase a 4/8 or 4/16 module, physically install it, don’t worry about partitioning the drive to get more file space, and enjoy some peace of mind and fewer failures.
Sounds like a bit of a sunk-cost fallacy if you had two Homey’s boot-looping on you and you still claim it’s the BEST.
Yes, I am guilty. I do see Homey Pro as a brilliantly designed product with great promise. After buying two hubs and two CM4 modules and suffering many lost hours, I am not entirely foolish. I have a new instance of HA running, ready to control my home if I throw-in the towel.
I think my main issue with Homey, besides the fact that it’s a closed system with almost zero debugging or fault-finding facilities, is that Athom as a company has always focused more on shiny new features than fixing or improving existing software.
Issues after firmware updates or with backups are well-known and have existed for years (like many other issues), but they just don’t get fixed, resulting in a device that becomes more and more unreliable, or at least untrustworthy.
I keep my Homey’s around as testbeds for my apps, but they don’t do anything else. Even then, my HP2023 drops its network connection about once every two weeks, for no reason whatsoever. And it’s the only device in my network (of about 80 devices in total) that has such issues. But this has also been a long-standing issue, where people have to deliberately dumb down their home network to 2009-standards to get Homey to work with it.
“It looks good from far, but it’s far from good” :man_shrugging:t3:
UPDATE: After researching this issue and narrowing the root cause, I thought that support would be interested in my findings and forward that information to a developer. I even offered to ship them the CM4 modules that experienced the unresolved RESTART LOOP, so they can look at the file system and diagnose the issue, and save many other users from losing their entire hub. There’s no response to my support ticket about resolving the issue, other than to say they’re glad my system is back online after replacing the CM4 module. That’s not something that the average user is willing to do.
I am disappointed in Athom :frowning:
UPDATE 2: After a followup request, support agreed to forward my concern to the development team. Later, the technical support person responded that the issue was being closed because the development team is already aware of the problem and won’t need further information from my investigation.
I have been experiencing similar problems to those you describe for almost one year. My hub was replaced once but the crash, reboot loop remains even with a minimal test configuration. So, I share your frustration and disappointment with Athom support who seem reluctant or incapable of providing a solution.
I am at a loss about fixing the issue. Perhaps I need to seriously consider abandoning Homey?
