Advice to reset everything
hello,
I have the last Homey pro since this summer
I have more than 60 devices deployed in a 70 SQm flat…
I have some issues every couple of days specially with devices on battery (Ikea blinds)…
yesterday I read an article in this forum about coordinator / router / and end devices…
I didn’t knew that during my initial deployment…
I check my Homey dev account online, and i have multiple disconnected zygbee devices and some in double…
I want to erase everything for a better and robust config
My question is simple can I do a factory reset to start from scratch , with my homey, the zygbee routers and only at the end of the process the end/terminal devices…
I’m ready to pair everything one by one…
is the factory reset enough or do I have to do more ?
thanks
Yes, but you could also reset Zigbee only.
And start only for zigbee over with first all Zigbee ppwered devices and then after that the Zigbee battery devices.
All zigbe devices will be reset during the new pairing.
thanks for the help
I do this from my dev tools page / zigbee / reset network I presume ?
Thanks
Yes
While you are at it, I would also make sure you don’t have overlaps in your zigbee channels and your wifi channels and those from your neighbors. Same apply if you also have Philips Hue hub and other hub that use zigbee
