Advanced flow pour gérer volet roulant - Advanced flow to manage roller shutter
Salut à tous,
Je cherche à automatiser le volet roulant de la chambre de ma fille avec un comportement spécifique en fonction de l’heure, du jour de la semaine, de la météo et des périodes de vacances scolaires.
Je sais que c’est ambitieux mais qui ne tente rien n’a rien :laughing: .
J’ai créé cet advanced flow pour que le volet roulant s’ouvre à 8h les lundis, mardi, jeudis et vendredi à 50% si la météo est bonne, à 100% si elle ne n’est pas, mais que qu’il ne s’ouvre pas pendand les vancances.
Pour cela j’ai récupérer l’application vacacances scolaires, et j’ai créé les vacances en fonction de ma zone.
I am looking to automate the roller shutter of my daughter’s room with a specific behavior depending on the time, day of the week, weather and school holiday periods.
I know that it’s ambitious but who doesn’t try nothing has nothing.
I created this advanced flow so that the roller shutter opens at 8 o’clock on Mondays, Tuesday, Thursday, and Friday at 50% if the weather is good, at 100% if it is not, but so that it does not open until next week.
For this, I downloaded the school holidays app, and I created the holidays based on my area.
Est-ce que cela vous parait cohérent ?
Merci d’avance pour votre aide.
Does that seem coherent to you?
Thank you in advance for your help.
The flow will not work as you want it to work
During the ‘vacances hiver’ the blue line is starting ‘état inactif.
At the same time ‘vacances printemps’ is not true. So the yellow line is starting ‘weather situation ‘
Is the a direct connection between ‘aujourd’hui lundi …..’ and ‘weather situation’? Remove that.
Connect all the yellow lines to a ‘ALL’-card and connect that card to ‘weather situation’
You want all the vacations to be untrue.
Thanks for your help.
Yes, I want that all vacations are untrue.
It’s correct like that :
Almost there: replace the top ‘ANY’-card by a ‘ALL’-card
Like that you think that is correct ?
You only should have replaced the top ‘ANY’-card.
The lower one was okay.
:folded_hands: thanks for your help.
