Hi, first of all pls excuse my bad english, its not my native language.
so here is my problem: i created an advanced flow. it will get startet by turn on or off a lamp. then a timer should check every 5 minutes if actual time ist between, lets say 23.00 in the evening and 6.30 in the morning. if thats true switch the lamp on, otherwise switch it off.
i hoped that the switch on or off in the end will lead the flow to the start again, creating someting like a loop but what really happend is - nothing.
A test shows, that the flow runs 1 time like expected but then stops at the end command (on or off) it will NOT return to the original condition.
here is the flow:
so can someone get me on the rail???
thank you very much in advice ![]()
