Hello so I am trying to set up a flow to control my AC unit (which also acts as a heater) the issue I have is people keep leaving the doors open. So I am using a shelly door switch and its connected to a homey bridge (due to distance from my homey pro) got it all set up, but it does not seem to work. Anyone spot the obvious? or what am I doing wrong? This is my first time of doing such a complex flow
I think you have the alarm turned on/turned off mixed up. And also the ‘dooropen’ true/false. When the door is closed the alarm is off.
But when the door is opened your flow waits 30 seconds before turning off the AC
Once these 30 seconds card is started it can’t be interrupted. So when the door is closed during these 30 seconds the waitcard will still finish and turn off the AC.
So you want to use a timer that can be stopped when the door is closed again.
