HI, i want to try this (See image)
if door is open for 30 minutes, then notifaction ** to user
if door is closed within the 30 minutes time window then a other notifaction to a user.
Is this possible?
I would say: “just test it and you know if it works”
one way tho find out… right ![]()
As far as I know you set an alarm, let’s say at 20:00.
When it is before 20:00 the alarm is set. At 20:00 the alarm will sound, and depending up on the implementation the alarm is set for the next day or the alarm is off.
Anyway, testing if an alarm is set, result immediately in a yes or no. Not in in a delay. Just start the flow manually and see the result of this card
