I have a situation that involves three independent Aqura contact sensors that independently can turn on my Garage lights. This works fine.The problem comes in when I want the lights not to turn off until all three contact sensors clear It doesnt seem to work. I have tried writing an advance flow and maybe I am just not doing something right. HELP
Welcome Patrick,
Here’s how I prefer to control lights without being left in the dark
If the 3 sensors are sitting in the same zone, you can use zone activity;
When using zone activity, it works like this:
- one / several / all sensors active: zone = active
- no sensors active: zone = inactive
Another advantage: you can add, remove, replace sensors without the need to edit the flow.
THank You, It worked great. My head was hurting trying to figure it out. Thanks again.
Here are two more options, just for your information:
- Using the < group > app to group all sensors. However, this app is only compatible with Homey Pro.
- Using this flow:
