Adding Aqara M3 to homey pro
Hi everyone, I just finished setting up the Aqara M3 and the process was super fast and easy! Now I’m trying to connect the M3 to my main hub (Homey Pro), but I’ve got a few questions:
When I added my first T2 GU10 to the Aqara hub, it asked which protocol to use. I chose Zigbee instead of Thread — was that the right option?
I paired the M3 hub with Homey through Matter. Is that the correct way?
When my Aqara bulb is connected to Homey Pro, it shows up as two devices: the T2 bulb and the M3 hub. Is that normal?
I tried making my first flow using the mobile app. I can see the flow card in the “When” section, but when I switch to “And” or “Then” and try to select the T2 GU10, it doesn’t show up in app section!! (screenshot attached).
In Aqara thread discovery page I see only 2 thread network the Apple TV one ( it is off and I don’t know how to delete it) and Aqara one, where is the homey pro thread network? Is it important to connect the m3 hub to it?
Feels like I’m doing something wrong, but I’m not sure what.
Hey. I can see no one replied. I want to do the same. Did you manage to get it all to work?
Thanks :folded_hands:t3:
Hi @Latin105fm i figured out how to do the automation correctly
