I added a few Fibaro Wallplugs without any problems. Then one too a little longer but the app said device added but when I look in devices it does not show.
When I try to add it again i get device already added.
Anyway to remove a device when it’s not showing up in devices?
My Homey version is 2.1.1, I tried to reboot it but it does not make any diffrence
Any advice?
// Felix
as this question is asked several times, and also answerd many many times…. USE THE SEARCH OPTION.
its there to be used
Thank you cert much for your CAPS LOCK ANSWER! Are you three years old?
The the remove device in Zwave settings doesn’t do anything at all. I tried that option.
Also I can no longer add any type of zdevice, all get the same error.
Thanks for the warm welcome to the forum btw
your very welcome,
You never mentiont that you couldnt add any zwave device anymore
and just to nag
with my 3 year i know how to use the search
Try to reset ur device, try to remove the device from Homey (even if it’s not added before) and then try to add the device.
And please keep the conversation on-topic. If u have any problems with other posts or other users, please contact a moderator and keep the post clean.
