Adax - App only detect one panel heater
I have two Adax Neo WiFi last generation panel heaters. 1000W and 400W. The Adax app found the 1000W. When I try to connect the last one it says that it can’t find any more units. Has anyone experienced the same problem?
Hello and welcome to the Homey forum.
Did you check / update the firmware as per instructions? The 400W might not be compatible when it runs older firmware
Hi! Thank you! Yes I did check that and the firmware was up to date. I deleted the panel heater from the adax app and connected it again. That fixed it :man_shrugging:
