Now that the app NetScan doesn’t work anymore on the latest Homey firmware, does anyone have an alternative way to execute a flow when a network device (receiver with static IP) comes online?
I’ve tried the UniFi app that has a presence function, but my receiver does not have WiFi and is wired, it does not show up in the UniFi controller when it’s powered on.
Smart presence app is scanning IPs and has flow triggers for online/offline. You can create Homey devices for each IP device and react on triggers in flows.
Yeah it basically tries a connection attempt and interprets the result of that to detect if a device was there or just nothing. Simple as that.
I would expect that NetScan does the same. Maybe.
Hmm… you could generate a diagnostic report and put your contact info into the message. The developer usually gets an email notification when such is done.
The “Smart presence” app just scans the IPs you set in the options.
I use this for presence check of mobile phones instead of build in presence. I also check Homey state to restart if offline for a while.
“person” device for smart presence with IP settings:
