I just transferred from my old 2019 to the new 2023 Homey
Most everything is now working ok, but I have issues with one button. The flow works as it should if I trigger it from the website environment. The trigger from both the button on the wall as from the android app get enormous delays. often it take 30-60 seconds and then a number of the buttons happen at once (almost like the tiggers are stored in memory and then quickly executed one by one.
I also often get to see nework request failed issues in the app
The set up:
in the wall a Tuya dual switch connected to a push button
on the other side of the room, the lights are connected to an eco dimmer
The flow connects these to together, but picking up the trigger from the tuya and turning on the eco-dims
This did work, but now it does not.
I did a PTP, reboot, and a longer wait, but no success.
So it seems not so much the flow itself as the initial device triggering. and it doesn’t matter if I trigger the device from the app, the website or pressing it on physically…
All other devices in house run normally
I already replaced it for an other tuya 2 channel dimmer, will now also try to replace it with a two channel switch (if I can find one)
When you turn on the device from Homey, does the actual device turn on immediately, or does that also take a long time? I’m trying to find out if the problem is with the actual device, or with the trigger just being slow.
the button turns lightly gray immediately, the small icon depicting that the light is on only turns when the rest of the flow is actually completed and the other light turn on.
Checking it now again, and the flow takes 15 seconds, and I get a timeout warning (eventhough the flow does get completed eventually)
You have a dimmer switch that you want to use as a trigger to turn on/off other devices, correct? Are there any devices connected to that switch at all? Or does it just serve as a “switch input”?
You can trigger the switch in two ways:
on the device itself
from Homey
Is the flow trigger delayed in both cases?
Have you tried a simple flow that triggers on the switch being turned on/off to send a push notification? That’s how you can test how fast Homey reacts to the switch being turned on/off.
It just serves as a switch input (and yes incorrectly using a dimmer iso a tuya 2 gang switch, as I didn’t have one lying around). if that is what is causing this, then I know what to do
and yes, its delayed in both cases.
Will try some simple triggers first and see the speed of Homey, when I get back home.
I also have a 1 gang switch which I will also use in this flow to see if it is the dimmer
Thanks Robert, have one lying around. currently working with the single switches, so going to keep it in, but will remember this for the next time, thanks!
