This topic is not actively monitored by Athom or Miele & Cie. KG.
If you have issues with this app, please report it to the Developer Mentioned in the App store, mentioning the version of the app + a good description of the issue.
Forum Discussion
Initial Discussion created by @GeurtDijker with info from the community
This is a WIKI topic, Please contribute or ask any Moderator to add/update/correct this Discussion.
Has anyone figured out how to get the app to sende a notice when a unit is finished with its program? I have been trying the following two with the washer and dryer, but none of them has worked.
The latter links to this topic as it’s dedicated support topic:
I suggest to keep [APP][Pro] reserved for “official”/dedicated app support topics.
In time it has grown a bit this way, and it keeps it clear this way…
Had also already flagged the post and asked the admins to change the topic title.
From the title, I guess that he means the Official Miele app developed by Miele, so there is probably no “common” thread.
@DirkG and I suggest you remove the [APP][Pro] prefix in your topic title. Adding “Official” as you just did, doesn’t make it better; worse even.
Better just mention in the message itself that it handles about the Miele app by Miele itself and name the topic “How to send notice when Miele device is finished?” or something like that. That covers your question far better…
I see Miele just released their own version, I would highly suggest using their official app. I will change the title of the other topic, since for now, there is now reason to use my version, and their app will probably be the best solution for almost everyone.
Hi Miele, thank you for this app!
I have two wishes:
It would be great if I can see if my hob is turned on or off
So I can see if its still on when I’m leaving home.
So I can turn on the lights above the hob when turned on.
So I want to be able to test this in the IF and in the ELSE.
I want to create a notification in my living room when the next item must be put in the steam-oven.
So, IF a new item has to be put in THEN generate the notification.
If the device has an on/off switch and it doesn’t provide an AND card for it, it should still be possible to check the global Tag for this capability witv a logic card. Search the device in the tag list and check if there is a tag for the on/off capability.
Hi all - I have the Homey-Pro and have downloaded the Miele app. i have several brand new Miele appliances and am able to add all except the oven. I have tried all available options that appear but am told no appliance can be found. Out of interest, the Miele app finds it without an issue and it is connected via wi-fi through that channel.
I have sent a ticket but no response there. Was wondering if anyone has experienced similar issues and has a hack for me. I have tried uninstalling, resetting as well as removing from the Miele app but it just doesnt help.
Trying here now
I’m trying to start my Miele dishwasher with the ‘Start’ command in the Homey app from Miele. Nothing happens. The Homey app is connected to the machine since I can turn it on/off without any problems. I can also start the machine from the Miele Android app. Does anyone have a tip on what might be causing the start command from the Miele Homey app not to work?
I found that my washmachine and Dryer are sending the status in the ENGLISH language to the homey app. And if you use a different language in Homey, the status is NOT translated to you native language.
You can make a simple flow that is triggert when the status is changed and then use the LOGIC value STATUS of that machine and give you that (via timeline or push message).
Then you get the status that the machine is sending to Homey.
And that status you must use to trigger something.
I informed Miele about this and i hope that the will fix this problem…
I’ve been using the app for quite a while now, and it’s working great for notifications — thank you for that!
However, I was wondering how to access the total power and total water consumption values. These figures are visible directly on the device, but I couldn’t find them exposed in the integration.
At the moment, I only see the “Energieverbrauch” (energy consumption), which refers to the current program, not the overall usage totals.
Would it be possible to include the total power and water consumption data in the integration in a future update? These values would be extremely useful for long-term monitoring and energy management.
