A script to check sensor last update
Hmm, I’m not sure, maybe LastSeen is not available for Homey 2019, if such case, you would need to use the other script.
@Peter_Kawa ,Peter, I guess you are not using this script for Zigbee, right? (just to verify LastSeen)
Hi Sharkys,
Can’t help indeed, I’m using Zigbee2mqtt.
The Homey version was indeed the problem. The other script (0.3b) is working on Homey Pro 2019 :slight_smile:.
Thanks for taking a look.
Thanks - awesome! I was looking for something to check on my Zigbee devices :smiley:
But…is there a way for me to only act if there are more than 0 devices in the list? Maybe have the script end with an error?
It returns variable / value tag already and you can act based on it
Hmmm…I have a card for HomeyScript returning a text tag. Is there a way to access the other tags? I get one tag, the #result. If I read the script correctly, should I have access to an #InvalidatedDevices and #notReportingCount ? If so, care to point me in the direction of which card to use instead of the HomeyScript returning text tag? Or…how to access the other variables if the text tag is done correctly?
Only the return command gets passed to the cards’ tag.
When you need multiple results, just write them to Homeyscript tags, which you can use in flowcards like device tags, and logic variables.
 * This script will create a few Tags for use in Flow.
 * It will remove them after 5 seconds.
// Create Tags
log('Creating My String...');
await tag('My String', 'abcdef');
log('Creating My Number...');
await tag('My Number', 123);
log('Creating My Boolean...');
await tag('My Boolean', true);
log('Creating Kitchen Light, false, true, value...');
await tag('Kitchen Light, false, true, value', 'NewValue');
// Wait 15s
for (let i = 0; i < 15; i++) {
  log('.');
  await wait(1000); // in milliseconds
// Delete Tags
log('Deleting My String...');
await tag('My String', null);
log('Deleting My Number...');
await tag('My Number', null);
log('Deleting My Boolean...');
await tag('My Boolean', null);
log('Deleting [Kitchen Light, false, true, value]...');
await tag('Kitchen Light, false, true, value', null);
return(true);
Awesome! Thanks! I wasn’t aware of that possibility. I did see the tags being created, but I wasn’t aware that they would be available anywhere but the flowcard’s output. This was awesome :slight_smile:
Would it also be possible to exclude a certain folder in this script, @Sharkys?
I usually put devices that I am playing around with, or not always plugged in (Christmas lighting, etc) in a certain folder. Would be nice if you could exclude such a folder from the script as well…
Check out 0.4 & 0.5 Zigbee only versions.
Damn, you’re quick!
Thanks a million! :+1:t2::smiley::smiley::smiley:
So both versions updated + made it little bit more user friendly + quickly tested, hopefully it will be working fine for everyone.
Hi @Sharkys ,
I’m not a DEV, but for me it looks like that the zigbee script (version 0.5) is not (only) for Zigbee.
I adapted the filter in line 14, and I see also non-zigbee devices.
You are actually right, mistake happened.
I am new to this thread and at a loss to find version 0.5 (stuck with 0.4).
Could you please point me to 0.5 ?
If you are looking for Zigbee version, it’s WIP (just limited by time). The other is just above ,scroll few posts back.
You can test Zigbee 0.6 version.
Changelog (any device type) :
Version 0.5 - better output formatting and fixes date times sometimes N/A
Changelog (Zigbee only) :
Version 0.6 - improved formatting of the output
The new version is much easier to configure and to maintain. Thanks @Sharkys for that.
I’m using the script in a card and send the output with a push notification to me if a device is nok.
In the new version are devices excluded in EXCLUDED_DEVICE_NAME_PATTERN also listed in the output. I think it would make sense if the output would be without these devices.
I’m not 100% sure, but I think it was handled in this way in the previous version(s).
Hm, you mean Zigbee version, right ? …hopefully fixed
