I have blinds with A-Ok motors. They operate at 433.92 MHz
Is homey compatible with 433.92 MHz?
Today I use a remote control or this AOK Blind Interface:
https://www.aokmotors.co.uk/aok-blind-interface-with-control4-driver
433,92 is a standard frequency for Homey so from that POV it should be possible. But the 433 signal will use rolling codes as an encryption (I hope for your sake). You can try to record the signal: https://developer.athom.com/tools/signals and see if you can get anything usefull out it with https://github.com/harriedegroot/Athom-Homey-RF-Signal-Analyzer
If you keep the “hub” you might be able to figure out what http-calls have to be send to the hub?
Or, maybe easiest: drop the hub and install a Zwave-device like:
https://www.robbshop.nl/domotica/projecten/z-wave-garagedeur
You got any more clue on this ?
Do you have already a solution for this?
Regards,
Leo
