[APP][Pro] Swedish Trafikverket weather
Weather from Swedish Trafikverkets weather stations
App Store Page: Swedish Trafikverket weather | Homey
Description
Get accurate weather information from any of Swedish Trafikverkets many road weather stations around Sweden. View camera images from road weather stations to see traffic situation and road conditions.
How to find my weather station
When adding a weather station device to your Homey you can either allow the app to show available stations within 20 kilometers from the location of your Homey, or you can search for a station by name.
To find available stations and their names you can use Trafikverkets website.
Otroligt cool app. Mycket användbar.
Jag lyckas inte komma förbi söksidan, oavsett vad jag skriver händer inget och Nästa-knappen förbli grå.
Jag bor mer än 2 mil från närmaste station, men skall det påverka? Stationer jag vill lägga till är ”Hamnäs” och ”Gruvberget”
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
Svenska (Swedish)
When I search for any of those they show up as stations I can add.
You can try and send me a manual diagnostic report. It is done from the app’s page in Homey.
I restarted my Homey, and now I could add the stations - great
Why can’t I see any camera images today on any of my places ?
I did push an update of the app, but have you tried:
  • restarting the app?
  • checking the API error in the settings on the device?
I see up to date cameras for the station that usually have cameras.
I have tried to restart but when I check my stations they are 11 hours ago even after the restart.
Api error:
2024-10-04T06:48:48.510Z ReferenceError: Request is not defined at Trafikverket.#invoke (/lib/tv_api.js:189:29) at Trafikverket.getWeatherStationDetails (/lib/tv_api.js:140:28) at WeatherDevice.refreshWeatherSiteStatus (/drivers/weather/device.js:118:25) at Timeout._onTimeout (/drivers/weather/device.js:159:18) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
fre 4 okt. 2024 kl. 08:52 skrev Richard Barkestam via Homey Community Forum <notifications@athom.discoursemail.com>:
Think I understand the problem, which version of Homey firmware do you run?
As of this version the app requires v12.0.1 or newer. However in some older firmware versions Athom had a bug which allowed it to install apps even if they specifically required a newer firmware version. There are other reports of this in the forum.
Either revert to the previous app version, or upgrade your Homey’s firmware. Not much else to do I’m afraid. Lots of apps will start requiring v12 or newer given there are benefits for developers.
I have 12.0.1 but I can see that it’s a 12.1.0 version I’m going to install now to see if that can solve the problem.
If I wan’t to try and install an older version of your program, where can I find those files?
Sincerely Michael
fre 4 okt. 2024 kl. 09:26 skrev Richard Barkestam via Homey Community Forum <notifications@athom.discoursemail.com>:
Same problem !!
Interesting … so there is a difference between HP23 and HP19 I assume
If you check on your Homey: general / system information / Node.js, which version is listed here?
V12.22.11
fre 4 okt. 2024 kl. 11:01 skrev Richard Barkestam via Homey Community Forum <notifications@athom.discoursemail.com>:
That is crappy … we have v18.20.4 on HP23 using same Homey firmware version.
I’ll try and revert the app version since it will not work for anyone on HP19 then.
Jag tror du pratar Svenska så jag går över på det :slight_smile:
Ja din app har fungerat klockrent tidigare och jag använder den dagligen under vintern !!
Kan bara berömma appen och har aldrig haft några problem tidigare
Med vänlig hälsning, Michael i Jonstorp/Höganäs några mil utanför Lund :crazy_face:
fre 4 okt. 2024 kl. 11:27 skrev Richard Barkestam via Homey Community Forum <notifications@athom.discoursemail.com>:
Installerade denna idag, men kan varken göra flow eller se något annat än att den är installerad bland apparna. Har startat om både Homey och appen flertalet ggr. Men ingen möjlighet till flöde kunde läggas till
Have you added a device? It is not enough the install the app, you need to add a weather station as well. There are a couple of hundred to choose from.
