Get accurate weather information from any of Swedish Trafikverkets many road weather stations around Sweden. View camera images from road weather stations to see traffic situation and road conditions.
How to find my weather station
When adding a weather station device to your Homey you can either allow the app to show available stations within 20 kilometers from the location of your Homey, or you can search for a station by name.
To find available stations and their names you can use Trafikverkets website.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
When I search for any of those they show up as stations I can add.
You can try and send me a manual diagnostic report. It is done from the app’s page in Homey.
I have tried to restart but when I check my stations they are 11 hours ago even after the restart.
Api error:
2024-10-04T06:48:48.510Z ReferenceError: Request is not defined at Trafikverket.#invoke (/lib/tv_api.js:189:29) at Trafikverket.getWeatherStationDetails (/lib/tv_api.js:140:28) at WeatherDevice.refreshWeatherSiteStatus (/drivers/weather/device.js:118:25) at Timeout._onTimeout (/drivers/weather/device.js:159:18) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
Think I understand the problem, which version of Homey firmware do you run?
As of this version the app requires v12.0.1 or newer. However in some older firmware versions Athom had a bug which allowed it to install apps even if they specifically required a newer firmware version. There are other reports of this in the forum.
Either revert to the previous app version, or upgrade your Homey’s firmware. Not much else to do I’m afraid. Lots of apps will start requiring v12 or newer given there are benefits for developers.
Interesting … so there is a difference between HP23 and HP19 I assume
If you check on your Homey: general / system information / Node.js, which version is listed here?
That is crappy … we have v18.20.4 on HP23 using same Homey firmware version.
I’ll try and revert the app version since it will not work for anyone on HP19 then.
Installerade denna idag, men kan varken göra flow eller se något annat än att den är installerad bland apparna. Har startat om både Homey och appen flertalet ggr. Men ingen möjlighet till flöde kunde läggas till
Have you added a device? It is not enough the install the app, you need to add a weather station as well. There are a couple of hundred to choose from.
