[APP][Pro][Cloud] Amber
Amber - Not just Storage. A Safe Way to Share
Adds support for Amber - (NAS) https://www.myamberlife.com / https://amberpro.net
Useful links
Usage
  • Install this app on your Homey.
  • Go to new devices - Fill in IP - Username - Password
  • Data will be fetched.
  • Check statuses or create flows.
Current features:
  • Switch off. (on requires physical button press)
  • Display CPU %
  • Display Disk %
  • Display Temperature
  • Temperature alarm
  • Display online time
  • Get notification when a value has changed.
  • Flows
WARNING
Using this app will prevent your HDD from Hibernation. I added a manual update card/button to the app if you don’t want the auto-update.
You can disable auto update in the Device settings
Supported Languages:
  • :uk: English
  • :netherlands: Dutch
Contributions
If you appreciate this app, contribute to future development by making a paypal contribution
or buy me a coffee on Ko-Fi or Bunq.me
image ko-fiimage
:laptop: Apps made by @martijnpoppen
See for more apps link below :backhand_index_pointing_down:t2: or just open the pull down.
Changelog
Live version and Test version
Changelog can be viewed on the app page.
To do:
  • [Feature Request] Implement Router - INVESTIGATE
Frequently Asked Questions
Q1: What is the purpose of this app?
A1: With this app it’s possible to gain insights in your Amber NAS
A2: Next to that it’s possible to shutdown/reboot your Amber NAS from Homey.
Q2: My HDD is not hibernating
A1: This app calls the AmberPro API. This will function the same as opening Amber OS, so it will wake-up your HDD
A2: To prevent waking up you can disable auto-update in the device settings.
A3: To keep getting updates, but minimize the HDD hibernation wake-up you can use the update data flowcard/button
Q3: I cannot find router functions
A1: The router part needs to be developed. Currently I’m investigating that part
New app update (test: 1.1.0.):
  • NEW: add file upload via FTPS
The file will upload to the home folder of the logged in user. In a folder named ‘homey-amber’
Example flow with Eufy doorbell image: Gedeelde Flow | Homey
ezgif.com-gif-maker
App is live! :smiley:
Amber App voor Homey | Homey
New app update (live: 1.1.1.):
  • FIX: login mechanism
CC: @JJ.Jan
Is Amber Pro app working with Homey Bridge? Or do we need to make another App for Homey Bridge on Homey Cloud?
@JJ.Jan
For now it’s not possible.
Because of these 2 things:
  • Amber Pro should be reachable via cloud. Because Local LAN is not possible.
  • To get this App in to the store we should have a verfied Homey Developer account. So that can be that Amber partners up with Homey. Or it should go via the app developer.
New app update (test: 1.2.1.):
  • NEW: add Router functionality - connected/disconnected devices
Note:
  • This only works when Amber Pro is set to DHCP mode.
  • This requires a router password in device settings
Flowcards:
default is admin1234 or Admin1234, then you can change
Yes!
But the FYI was because of the new APP functionality :wink:
New app update (test: 1.3.0.):
  • NEW: add AmberX
  • CHANGE: app name to Amber
New app update (test: 1.3.4.):
  • NEW: add AmberX
  • FIX: enable FTP for Amber X
  • FIX: router for Amber Pro when interval disabled
New app update (test: 2.0.3.):
  • NEW: Homey integration (no bridge needed)
  • NEW: improved paring for Homey Pro
  • NEW: add login instructions for cloud
Note: This update can cause your current installed devices to break.
  • If that’s the case. Replace the username and password with your admin account which you use for the local webpanel.
  • If that doesn’t work. Please remove and pair again.
Sorry for the inconvenience :slight_smile:
New app update (test: 2.0.10.):
  • FIX: issue with login [Pro]
  • FIX: amber ip discovery
New app update (test: 2.1.0.):
  • NEW: Homey (cloud) integration
New app update (live: 2.1.2.):
Amber is now available on Homey Cloud! :tada: . (No bridge required)
