I built a Homey app for the Ratio Electric EV chargers.
What the app does
Pair with your Ratio app email and password, then see from Homey:
Charging power, status and mode
Which vehicle is connected
Energy charged today and in total*
Firmware information
Errors
WiFi/Ethernet connectivity
* The charger itself doesn’t keep a running kWh counter, so the “charged today” and “total” values are estimated from power readings, and can be slightly inaccurate after a brief interruption in the connection to Ratio’s cloud.
From Homey (or through Flows) you can start or stop charging, change the charging mode, and optionally set a maximum charging current (Basic mode only). Flow cards let you read or set the charging mode, assign a specific vehicle to your charge, and react to charging being blocked, your power being reduced by the grid operator, or a firmware update becoming available. There is also a dashboard widget that shows charging status at a glance.
Feedback, bugs and suggestions are welcome here in this topic.
Disclaimer
Unofficial, not affiliated with Ratio Electric. Built on aioratio, an async Python client for the Ratio EV Charging cloud API, which is itself unofficial too. Use at your own risk.
Added: the widget now shows the current charging session’s energy.
Added: you can now choose which parts of the widget to show — current session, charged today, and the charging control can each be turned off individually.
Changed: the widget now refreshes every 5 seconds instead of 30, so you’ll see more up-to-date numbers while charging.
Changed: improved code quality and fixed several minor bugs.
Sorry about that! This app is built with Homey’s Python Apps SDK. The Homey Pro (2016–2019) can’t run Python apps at all, so unfortunately there’s no way to install it on that model.
Check the widget settings: edit your dashboard, open the settings of the widget, and make sure “Show charging control” is turned on. That setting shows or hides both the charging switch and the mode dropdown.
Hi, I ordered the Ratio Solar MID with load balancing, but I have a question about using it with Homey and a home battery, for example:
Can the charging current be set while in Smart/SmartSolar (load balancing on), e.g. via the minimum charging current? It looks like the current card only works in Basic.
