I have just created an app for the Warmup/MyHeating
Perhaps there are some users who want to test this for me?
It is derived from a github I found (for Home Assistant) and they mentioned the IE4 would work, but perhaps the IE6 as well.
I’m using it for IE4. I have 6 thermostats. It looks good, but I found a bug/limitation.
When you change the mode, you can only change between “Program” or “Fixed Temperature”. If you set it to anything else, it will revert back to the previous state after a few seconds.
See screen cam. https://drive.google.com/file/d/1vPL9Yd4Ki3q95sCaUJD4j2pQi9NM1nkL/view?usp=drive_link
Thanks for your effort and support.
Thank you for your feedback, I have updated the app once more.
I made a mistake with the thermostat modes, you only have two, program or fixed.
Next to this I noticed the app crashed during setting the mode, this should be fixed as well.
Power measure is added as well as the device is telling me.
Please note:
Setting the thermostat is based on room, not device. So if you have multiple devices within 1 room, I do not know what is happening.
As for your request about the heater, this is a thermostat with the functions that come with.
As the thermostat does not have a off mode, I am unable to turn it off
Second note:
I notice the API is taking some time before accepting the new settings, so it could lookslike the thermostat is reverting back to the old value, but after 20 seconds or so it is reflecting the correct value.
I am trying to find a solution for this, but for now no luck in this
Sorry for slow response but since last uppdate the behaviour have become weird and i have tried to nail down what it is.
Here is a diagnostic report
fcd15a10-8a0a-432a-9503-16d119aae627
To give one specific example. One thermostat (Master Bedroom) allways goes to 22,5 if mode is set to program. This value does not exist anywhere for this thermostat.
See screen can
https://drive.google.com/file/d/1wAC4Q7dJsguuNewh6Dc3zLVU93bT5978/view?usp=drivesdk
Om happy to provide more screen shots/cams but please let me know if there’s any specific you would like me to send.
Thanks
/Joakim
Den tors 15 jan. 2026 19:32Martijn de Bont <notifications@athom.discoursemail.com> skrev:
Dear Martin,
This is great ![]()
I have just installed it and it looks like it is working ![]()
I will continue testing and will let you know the outcome.
THANKS ![]()
/Joakim
Den ons 14 jan. 2026 14:14Martijn de Bont <notifications@athom.discoursemail.com> skrev:
Hi again,
one immediate observation.
Warmup should be possible to defined as a heater.
Besides that everything looks fine so far ![]()
Thanks
/Joakim
There seems to be a bug/limitation.
When you change mode you can only change between “Program” or “Fixed Temperature”. If set it to anything else it will revert back to the previous state after a few seconds.
See screen cam.
/Joakim
Den ons 14 jan. 2026 19:43Joakim Gustafsson <joakim@brilink.se> skrev:
(Attachment screen-20260115-105857-1768474692093.mp4 is missing)
Hi, I’m planning to buy the 7iE thermostat. Has anyone already managed to get it working with the app? And if not, are you satisfied with your Warmup underfloor heating system?
