[APP] Virtual Gas & Water Meters
[Release] Virtual Gas & Water Meters — Cumulative meters for Homey Energy
Hi everyone! :waving_hand:
I’ve built a small app that adds virtual cumulative meters for Gas and Water so you can track them in Homey Energy with history and use them in Flows.
What it does
  • Adds two device types:
    • Virtual Gas Meter (meter_gas, m³)
    • Virtual Water Meter (meter_water, m³)
  • Works as cumulative measuring devices → shows up in the Energy tab (Gas/Water).
  • Comes with Flow actions to set, increase, and reset the counters.
Why?
Many of us have readings from an external meter (utility bill, smart valve, manual readings…) and just need a simple way to keep a running total in Homey, see trends in Energy, and automate updates via Flows.
How to install
Add a device
Devices → + → Virtual Gas & Water Meters → choose Virtual Gas Meter or Virtual Water MeterAdd.
Make it show up in Energy
Energy needs at least a couple of samples to draw deltas:
  1. Open the device Settings and ensure Exclude from Energy is off (if available on your build).
  2. Trigger a few small increments with short delays (e.g. +0.05 m³ two or three times).
  3. In Energy → Gas/Water, switch the timescale (e.g. Last 24 hours) to refresh.
  4. In case that there is still no data after few hours, try to reset App
These counters are cumulative – values should generally increase over time. A manual reset is supported but will impact charts.
Flow cards (examples)
  • Set gas meter to… → set an absolute reading (e.g. from your monthly bill)
  • Increase gas meter by… → add a delta (e.g. daily/weekly usage)
  • Reset gas meter → set back to 0 (use with care)
    (Same trio exists for Water.)
Known notes
  • The “Tracks total home energy consumption” toggle typically applies to electricity; for Gas/Water you’ll mainly see Exclude from Energy (depending on your Homey version/UI).
  • If Energy shows “No data available”, send a couple of increments and change the timescale; the panel usually populates immediately after new samples arrive.
Feedback
Bugs, ideas, questions? Please reply here with:
  • Homey model & firmware version
  • App version
  • What you tried (e.g., Flow steps)
Thanks for trying it out! :folded_hands:
— Martin
Hello Martin, just installed your app, build a flow to give input (via push message with question) and that works fine! Just… I entered a decimal and I can’t figure out if you app is able to register decimals. This is for water a wish.
I don’t have gas but oil. I measure it in liters and enter for example 518 liters as 0.518
Here I miss a third decimal. So a second wish :slight_smile:
I wil further try the app the next months. Thnx! This helps a lot
I have been playing with GitHub - jomjol/AI-on-the-edge-device: Easy to use device for connecting "old" measuring units (water, power, gas, ...) to the digital world · GitHub to read values of a hidden meter. I haven’t finished a working setup yet, but together with the virtual meters app, this might be a great combination. Not sure how they should fit together exactly, but having meter readings from another input into Homey Energy would be great!
