[APP] Nimly - Welcome (to a smarter) home
Central topic for questions/discussing the Nimly App. You can use this topic to ask questions and share your experiences with the devices from Nimly.
This thread is not actively monitored by Nimly AS or Drenso. For official support use the e-mail link in the AppStore Support Contact ».
I have issues?
  • Why is away mode not supported (activate/de-activate the indoor handle)?
    Away mode is not intended for everyday use as it could compromise an otherwise easy escape in case of fires or emergencies. For this reason it is not available to configure using the Homey application.
  • Can the lock be connected to both the gateway and the Homey app?
    It is not possible to connect the lock with both the Nimly Gateway and Homey at the same time: you will indeed need to choose one. This also means that you indeed to remove it from the Nimly gateway before you can add it to Homey: the lock Zigbee module might still need to be reset before you can start adding it the Homey.
  • How can the flow cards be used for doorlock events and managing users.
    See below for a couple of suggestions.
  • Will the EasyFinger V2 be supported?
    The EasyFinger V2 is an older electronical door lock that is end-of-life (it was launched back in 2018). As it does not have the required smart module slot it is not possible to add Homey support. We recommend an upgrade to a modern Nimly smart lock.
Flow suggestions
The Nimly BLE module drains the batteries in 3-4 weeks. Installing the module in order to use the Nimly app is therefore in practical terms a no go.
I have approached Nimly twice with the problem and they promptly sent a new module. However the new modules were as power hungry. The app itself works fairly sell, but with the frequent battery changes, I had to remove the card.
Has anyone else experienced this?
Conclusion from chatgpt:
The battery drain is caused by Nimly’s Zigbee module (SIGMI) advertising itself as a non-sleepy, mains-powered end device, which is inappropriate for a battery-powered lock.
There is currently no OTA update path, and newer Zigbee modules show the same behavior.
This appears to be either a firmware bug or a design decision in Nimly’s Zigbee implementation.
Have same issue here, changed the batteries 3 times since November and guessing is because of the connect module which is only 2m from Homey. Will try without the module and see how long will last this time.
Same issue, its kinda useless now. 20 days and battery replacement…
Tried reaching out to Nimly also but still no response. Maybe time to look for an other brand?
Got in touch with the support and they offered to send a new module with newer firmware. Took one week for me from sending the mail to receiving it. For now it’s been one week with the new module and looking promising.
Thats great to hear! Still working good? How did you contact Nimly? I’m trying but no reply on mail either from Nimly site or the link in the Homey App contact
Been 3 weeks now and I can say the ZigBee connection with homey is very stable while very little battery drainage. I guess the new module with newer firmware solved the issue.
Contacted the support using the existsing email address on their webpage. They replied in less then 24h and believe they’re aware of this issues as no extra question asked.
I got in contact and they sent me updated module. I have used it for 14 days now and its working, maybe too good as its still reporting 100% battery. So now I worry it doesnt report correct battery status…
The module update only prolonged the battery life by 10+15 days, as after 30 days had to change the batteries again. Then with the new batteries in place 3 days later the battery status dropped from 100 to 70. Maybe it’s time to move on and look at other smart locks alternatives.
Did you get updated battery status before it died, or just 100→ 0 (and good luck chuck)?
I got status from 100 to ~75 in the first 7 days then ~55 after 2 weeks more and nothing since the lock started beeping 5 times with each door opening and until it died. Yours is till att 100% since you got you module ?
Yes. I have two locks and got replacement module for both. They have been installed for 4-weeks and 1-week and both show 100% and has since it was installed. I’d prefer they went down bit by bit…
Firmware version: 4.8.01
Hello.
I trying to connect my new Nimly to my homey pro early 2019 without success.
I have the connect module but not the nimly gateway. Do i need the gateway?
Btw i can not connect the module to my phone using bloutooth.
I’m not familiar with Nimly, but there’s a dedicated app topic for it:
If you cannot find the answer in that topic, you could reach out to Nimly support as suggested in the topic start.
Hi, any suggestions, I have received a new updated BT module. All working well with Homey.
But suddenly it has lost its connection to Homey. New batteries and I have tried to use Homey dev.tools to repair but with no luck.
Its situated in a remote cabin, so I can’t access it hands on.
Anyone having the same problem with lost connection? Any suggestions how to fix this?
Homey is 2 meters from the lock and I have an extra smart plug close to the lock to boost connection.
Don’t really have a solution ( maybe try to restart Homey) but from my experience the module lost the connection to Homey only when the batteries needed to be replaced or after I bought a Nimly rechargeable battery and during the time it was charging. For me the classic turn Off and On did the job without the need to add the module again to Honey.
More to my story, unrelated to the above question, I am now on module nr 3 ( first 2 modules been draining the batteries in 2 weeks ) and on a second lock as previous stopped unlocking ( motor issue ) only after 5 months. Lucky enough the support has been very helpful each time and send out a replacement. Hopefully this time all issues are sorted out, time will tell.
For some reason, I’m not able to see who has unlocked the door. This is my current flow and the test confirms it works as intended. I’m 100% sure that the associated ID’s are correct.
I have Nimly Touch Pro. Can anyone see any obvious mistakes here?
I’m fairly dissapointed of Nimly for not supporting home automation through their gateway.
I bought the lock since they advertised the ability to create codes for limited times and having homey integration. It wasn’t specified this was an either/or thing. Now I have to pick between having the lock connected to my Homey, or being able to create limited time codes.
If anyone has a work around, I’d love to hear about it. Currently I’d not recommend this product for someone intending to use it for Home Automation for this reason.
Not sure I follow here. I do not have the Nimly Gateway so cant answer from that perspective. But this sentence is more about you not being able to create limited time codes? That should be possible by creating a Flow. Here is an advanced flow that should work.
But yeah I think Nimly should work a bit more on this product it is not perfect by any means.
