Marstek Homebatteries - Complete Energy Storage Management
Transform your home into a smart energy powerhouse! This Homey app brings full control of your energy storage system directly to your fingertips, enabling intelligent automation and optimal energy management like never before.
Unlock Your Energy Independence
Take complete control of your home’s energy storage with sophisticated automation capabilities that adapt to your lifestyle and energy needs. Whether you want to maximize solar self-consumption, take advantage of dynamic energy pricing, or ensure backup power during outages - this app makes it all possible!
You need Modbus over TCP support for your Marstek battery for this app to work.
Using the Modbus we are in full local control of the device.
Venus V2
I uses an EW11 device (about 22 euro’s on amazon) to convert the serial Modbus port to TCP.
For more details on creating a modbus tcp gateway, check out this dutch community:
Venus V3
It support TCP modbus on the UTP port nativly. However it is a weak connection. It is easily overloaded for example, so if you plan to do high speed control using the Homey EMS apps that are out there I still advices to use the serial gateway route like the V2 uses (see above).
Once the device is added, use the device settings to configure it to match your IP addresses.
You can now control your device fully from Homey to allow smart charging for your desired strategies.
It has been tested with Venus V2 devices and is expected to work with V1 systems, just make sure to use the correct pin layout for your tcp gateway cable.
The V3 is very new and seems to have a different cable (pin layout in the dutch community) but more important uses different modbus registers, it has been confirmed that the app works with the V3 in the same route.
Test channel
Main release
