[APP][Pro] Universal TUYA Zigbee Device App - test
Universal Tuya Unified Engine v7.4.9
323 drivers · 3488+ fingerprints · Updated 2026-04-23
Local-first Zigbee control for Tuya devices on Homey Pro the most comprehensive Tuya app available.
Install
Stable: Homey App Store · Test: Test Channel
What’s New (v7.4.9)
:milky_way: UNIFIED ENGINE - Critical Stabilization & Syntax Purity. Fixed ‘Unexpected token :’ in tuyaUtils.js:118. Implemented app lifecycle cleanup (onUninit). Restored corrupted math in core drivers.
Supported Devices
Category Drivers FPs
Socket 79 634
Light 38 250
Sensor 93 1564
Thermostat 23 203
Windowcoverings 8 86
Lock 5 22
Fan 17 239
Doorbell 2 8
Remote 19 39
Button 2 6
Heater 4 9
Garagedoor 3 5
Other 25 423
Device Finder search by fingerprint
Features
  • Tuya DP protocol (CLUSTERS.TUYA_EF00/TS0601) + Standard ZCL clusters
  • Physical button detection · Virtual buttons · LED backlight control
  • Energy monitoring (W/V/A) · Air quality sensors (CO/VOC/PM2.5/HCHO)
  • Covers & curtains with tilt · TRVs · Dimmers · IR blasters
  • Auto-configured settings · Diagnostic reports
Changelog
Previous versions
v7.4.8: Optimized build size for stability. Removed redundant xlarge assets and legacy data. Architectural stabilization of flow cards and driver logic. Zero-defect verified.
v7.4.7: Hotfix. Critical: Fixed syntax error causing permanent app crash on startup. Users experiencing ‘App crashes’ errors should update immediately. No breaking changes, safe upgrade from v7.4.6.
v7.4.6: Critical Image Fix. Resolved validation failures across all drivers by standardizing large.png assets to 500x500 @ 50KB+ requirement. Improved CI/CD robustness and driver asset integrity.
v7.4.5: Shadow Mode Enforcement. Unified maintenance now operates silently in background. Resolved False Battery Alert for VISION and TS0601 mains-powered sensors. Hardened SDK 3 compliance across core libraries.
Report a Bug
Open a GitHub Issue please include your _TZxxxx fingerprint and TSxxxx model ID.
Support the Project
This app is free and open-source. If it’s useful to you, a small donation helps keep it going:
PayPal: paypal.me/dlnraja · Revolut: revolut.me/dylanoul
Last updated 2026-04-23 Source on GitHub
It is unlikely that Athom will accept your version of the app to the store:
  • An app must have unique app id, your’s will conflict with the existing app.
  • There is a loose policy of one app per brand, but Athom has recently allowed multiple.
It is best you read the https://apps.developer.homey.app/app-store/guidelines
Okay i will see if i can change the name
I have no idea if it is something I could use😁.
For example could you elaborate on “ * Homey SDK3 compatibility optimization with modular, scalable architecture”. Is that an update of Homey SDK3 software? How do I update that?
name to “Universal TUYA Zigbee Device” i will apply it soon
when you do the homey app install from the zip of the github repository , it will dowlioad all right dependencies with the right sdk .
I have not finish yet , i’m working on the repo.
I thought it is the task of the programmer to use the right library and use the functions in that library.
I will check about the SDK update regulary.
It’s not usual to use the word community in the title of an app topic; this only shows in the app store. Here your AI advisor gone wrong?
Usual formats:
Homey Pro: [APP][Pro] Appname
Homey Pro & Cloud : [APP][Pro & Cloud] Appname
or
[APP] Appname
Another thought, because you don’t mention him at all: is @johan_bendz okay with all this? I assume you based “your” app on his app code?
And another thought: The “ad” sounds very “too good to be true” (no offence), you just promise waaay too much imho. I’d just extend things bit by bit.
And don’t trust on AI too much. AI is not very smart (yes I’m from the pre-AI gen hahaha).
I would assume so, since his app is MIT-licensed, and the MIT license is very permissive.
The projet is on mit liecence.
On other Homey thread or post, they say of one dev dosen’t maintain a projet during more than 1 year , the project can be redonne by someone else.
Whats the better title you suggess ??
Thanks. Then it would be a nice thing for dlnraja to at least mention Johan and/or his app. But that’s just my humble opinion.
Yes its will take times it will not be done right now.
All the feature is a to do list to be implemented on long term. Step by step.
Sorry if my english is not good enough. I’m french :sweat_smile:
Already mentioned on the crédit . Will bé updated soon.
I’ m based on his code but it was not full SDK v3 it was on sdkv2/v3 hybride i i have evolved it to full v3
I do it as at my free time
If they dont accept it will be a project only for me that i can download from github and install manualy.
Hi Dylan, I admire your patience and good work.
Hopefully Athom is allowing you to continue with your good work and also Johan Bentz is pleased toooooo to see his app is continuing and growing.
Thanks again for all your effort,
Best regards Peter.
Thank you very much for taking over the app to continue its development.
Will it be available in the app store? As an update to Johan’s app, or as a new app?
I havent requested to be on the app store
Personnaly i unzip it and will install it with the commande Homey app install.
I will do it when its done
Now i have some issue to fix on the project
All right, thanks :slight_smile:
I’m in no rush; Johan’s app is enough for me for now, but a more advanced and generic version for unsupported devices would be nice. Will it be a new app, or an update to Johan’s?
How can we contribute to the development?
