ITEAD Sonoff
Current app version: 4.0.7 (stable)
Provides support for ITEAD Sonoff devices.
!! deprecation notice !!
I stopped working on this app because I stopped using Homey a long time ago. It only supported very old versions of the Sonoff firmware, and very old versions (at most v6 or possibly v7) of the Tasmota firmware.
There is a dedicated Tasmota app that may work better for you: Tasmota MQTT App for Homey | Homey
Links:
- App Store: Sonoff App for Homey | Homey
- GitHub: GitHub - robertklep/name.klep.sonoff: Homey driver for Sonoff devices
- Issues: GitHub · Where software is built
Original Firmware information
Devices running older versions of the original Sonoff firmware (for the Basic and S20 devices, before firmware version 1.6.0) are supported “out of the box”. Instead of pairing the device with the eWeLink app on your smartphone, you can pair it with Homey using a relatively simple procedure (explained during the pairing procedure). Feature support for the original firmware is limited: only switching the device on/off is supported.
Devices running newer versions of the original Sonoff firmware cannot be paired with Homey (the manufacturer removed this ability).
Sonoff-Tasmota Firmware information
This app also supports Sonoff devices running the Sonoff-Tasmota firmware. This alternative, open, firmware can be “flashed” into most Sonoff devices. The flashing procedure does require some hardware skills, and falls beyond the scope of this app (however, if you have questions about this, feel free to ask me).
This app uses the MQTT protocol to communicate with Sonoff-Tasmota devices. This requires an MQTT broker. The MQTT Broker app for Homey provides such a broker.
Supported Devices
The following devices have been tested with this app (either by myself, or by other users). The firmware they were tested with is mentioned as well (not all devices were tested with both firmwares, so only the tested firmware is mentioned):
Sonoff Basic WiFi Wireless Switch (original firmware and Tasmota)
Sonoff S20 Smart Socket (original firmware and Tasmota)
Sonoff RF WiFi Wireless Smart Switch With RF Receiver (original firmware)
Sonoff Slampher (original firmware)
Sonoff RF Bridge (Tasmota)
Sonoff TH10/TH16 (Tasmota)
Sonoff Dual (Tasmota)
Sonoff 4CH (Tasmota)
Sonoff POW (Tasmota, R2 as well, but untested)
Sonoff T1 1-/2-/3-channel (Tasmota)
Questions
The quickest way to contact me is through Slack ( @robertklep ).
