Zooz outdoor motion sensor 800 & zooz outdoor sensor
I just try zooz zse41 door sensor 800 connect to Homey Pro. I have 3 to connect but it’s only 1 was succeed. The other 2 won’t connect. I’d try to asked zooz support and they said try inclusion mode.
Is there any body know how to do that?
Thanks
Did you read the kb articles about z-wave?
All articles:
https://support.homey.app/hc/en-us/search?utf8=✓&query=z-wave
I’ve found Zooz wire power devices like wall switches and appliance switches to be awsom, reliable and I don’t hesitate buy them. The battery powered devices seem more finicky. On pairing, when the instructions say quickly triple click the pairing button, try slightly slower. They seems finickier on distance even though there plenty of repeaters near by. Seems my garage is a no battery powered Zooz zone but the same Zooz connector tgat would work in the garage has been rock solid on the front door. All of my Aeotech sensors in the garage all work well. Also if using an iPhone and you can get past the 2 3-button presses enter the pin then it fails. Don’t hit the dine button to minimize the keyboard, instead just hit the enter key.
After several failed attempts I was able to connect the motion sensor. It had always failed at accepting the pin prior. The sensor works for a few days then disconnects. I repeated a second time and all seems good, then it disconnected again. It seems to work better and easily connected on the third attempt but without encryption (PIN=0000). If it disconnects again I just move the motion sensor just out the window near where honey is located. I had an another similar experience with a Zooz contact sensor but when I relocated to another door closer to the hub it has been flawless. I have plenty of repeaters zwave repeaters around but it seems Zooz won’t go beyond the first node closest to homey pro.
This has my experience with Zooz. Where’d powered devices work very well but battery devices are bit testy.
It’s been a week and my Zooz zen70 has been working well without encryption. (Pin=0000). I’ve noticed the app doent alway update current state nut this is just a UI thing.
