Here are my measurements. I do not see where Homey fails (but I do not have the issue).
Homey: HP2023
Measurements are approximate.
Sensor: Hue motion sensor on Matter
I did this three times.
Test 1: 4% CPU load. Memory usage around 440MB
Test 2: 2% CPU load. Memory usage around 440MB
Test 3: 2% CPU load. Memory usage around 440MB
Results: Test 1/Test 2/Test 3
Tested with both Simple flows and Advanced flows.
- Zone activity is 71/79/159ms after sensor motion arrives to Homey. This is the time it takes for Homey to process.
- Motion sensor turns to inactive after 10s. Zone inactivity is 109/150/108ms later.
- Zone inactive for 1 min is set after 1 minute and 2ms/7ms/5ms: this is a very short time as there is no sensor processing, just the zone timer.
For comparison (very similar):
Sensor: Hue motion sensor on Philips Hue app
- Zone activity is 95/78/127ms after sensor motion arrives to Homey.
- Zone inactivity is 98/95/84ms after the sensor inactivity.
- Zone inactive for 1 min is set after 1 minute and 4ms/3ms/4ms
