Zone inactive for x minutes triggers, while there is motion, leaving me in the dark
Thank you @Rmb , My findings in my logging now, is like your’s, I find that disturbing, when my experience without the logging is different. The logging confirmes that the timer start at new again when the zone sais that is no movement.
*The first message is “Zone active”, the one you can not see in the “snip”.
When i implenteded the check of “zone active” after the “zone inactivity XXminutes” everything was solved. There has to be a culprit somewhere. I do not understand this. When i have been in the Zone again, and it is active in app, the lights turned off because the floe said “so”.
