Zemismart ZM25AZ01 Roller Shade Motor TS0601_TZE200_m6lwazh9
Buenos días:
He comprado 5 Zemismart ZM25AZ01 Roller Shade Motor, con las siguientes características:
Modelo: ZM25AZ01
Protocolo: Zigbee
Model ID: TS0601
Manufacturer: _TZE200_m6lwazh9
Homey: Homey Pro
PROBLEMA: Homey Pro incorpora el dispositivo, pero aparace como “UNKOWN ZIGBEE DEVICE”, y no puedo realizar ninguna acción con el dispositivo, y no puedo programar flows.
La App de Zemismart tampoco reconoce el dispositivo.
Me gustaría solicitar a ZEMISMART que añadiese a su APP de Homey Pro soporte para esta variante.
EN INGLES:
Request for support: Zemismart ZM25AZ01 Roller Shade Motor – TS0601 / _TZE200_m6lwazh9
I would like to request support for the Zemismart ZM25AZ01 Roller Shade Motor in Homey Pro.
I have purchased 5 units of this motor and I would like to control them directly from my Homey Pro via Zigbee, without using a Tuya gateway/hub.
Homey detects and pairs the motor successfully, but it is identified as an Unknown Zigbee Device.
The device information shown by Homey is:
  • Manufacturer: “_TZE200_m6lwazh9”
  • Model ID: “TS0601”
  • Device: Zemismart ZM25AZ01
  • Type: Zigbee Roller Shade Motor
  • Homey: Homey Pro
I have also tried the existing Zemismart Roller Shade Motor driver, but Homey does not recognize this particular fingerprint.
I also tried the Tuya Zigbee → Curtain Motor driver, with the same result: the motor is detected as an unknown device.
Could you please consider adding support for:
“_TZE200_m6lwazh9” / “TS0601” → Zemismart ZM25AZ01
Ideally, I would like the motor to be exposed in Homey as a normal window covering/roller shade device, with at least:
  • Open
  • Close
  • Stop
  • Position control (0–100%)
  • Flow support
I can provide the complete Zigbee fingerprint, interview information, endpoints and clusters from Homey Developer Tools if required.
Since I have 5 identical motors, supporting this fingerprint would allow all eight units to be integrated into Homey.
Thank you.
@Zemismart_Official might be able to help you
kindly try this if it can help: Zemismart | Homey
