Zemismart ZM106 Matter Smart Wall Switch – Premium Hardware Design with Direct Homey Integration
Zemismart ZM106 Matter Smart Wall Switch, a new generation wall switch designed for modern Matter ecosystems, including direct integration with Homey Pro.
With Matter technology, ZM106 can connect directly to Homey, providing a simple and stable smart home experience without requiring an additional gateway.
Native Matter Support – Connect Directly with Homey Pro
The ZM106 supports the Matter over Wi-Fi protocol, allowing users to add the switch directly into their Homey ecosystem.
No extra bridge is required.
After adding ZM106 to Homey, users can enjoy:
  • Remote ON/OFF control
  • Smart home automation
  • Scene creation
  • Voice control through supported Matter platforms
  • Reliable local smart home integration
For Homey users who prefer a clean and flexible setup, Matter provides a future-proof solution with broad ecosystem compatibility.
Built for Quality: Premium Materials and Strong Structure
Unlike many standard smart switches that focus only on electronics, Zemismart pays special attention to the physical quality and safety of the product.
The ZM106 uses:
:fire: Flame-retardant PC material
The switch body is made with high-quality flame-retardant materials, improving safety and durability for long-term household use.
This provides better heat resistance and helps protect the internal components during daily operation.
:flexed_biceps: Metal Back Plate for Better Strength
The ZM106 features a reinforced metal back plate design.
Compared with traditional plastic structures, the metal support provides:
  • Higher mechanical strength
  • Better installation stability
  • Improved durability after repeated installation
  • A more solid premium feeling on the wall
A smart switch is used every day, so the mechanical structure is just as important as the smart features.
Designed for Modern Smart Homes
The ZM106 combines a premium physical design with the latest smart home technology.
It is suitable for:
  • New smart home installations
  • Home renovation projects
  • DIY Homey users
  • Matter-based smart homes
  • Professional installers looking for reliable hardware
Whether you are controlling lights, creating automation routines, or integrating with other Matter devices, ZM106 provides a stable foundation for your smart home.
Why Choose Zemismart ZM106?
:white_check_mark: Matter over Wi-Fi support
:white_check_mark: Direct connection with Homey Pro
:white_check_mark: No additional hub required
:white_check_mark: Flame-retardant housing material
:white_check_mark: Strong metal back plate design
:white_check_mark: Premium build quality
:white_check_mark: Designed for long-term smart home use
We believe smart home devices should not only be intelligent, but also dependable.
The Zemismart ZM106 brings together Matter compatibility, strong hardware design, and reliable performance to create a better smart home experience.
Product page:
