Zemismart Zigbee LED Strip Controllers – Lighting Control in Homey (ZMZ-03SL & ZMZ-03SL CW)
Hello Homey Community,
We’re pleased to introduce the Zemismart ZMZ-03SL series of Zigbee LED strip controllers, with options for both RGB color lighting and adjustable white lighting. This post highlights the ZMZ-03SL (CW) and its lighting controls in the Homey interface.
From switching your lights on and off to adjusting brightness and white color temperature, the screenshots below bring together the essential controls for everyday lighting.
Your Lighting, at a Glance
The Homey device dashboard displays ZMZ-03SL and ZMZ-03SL (CW) as separate devices. In the setup shown below, the CW device tile displays its on/off status and current brightness level, making the lighting state easy to check at a glance.
Adjustable Brightness
Set the lighting level to suit the moment using the brightness slider in the ZMZ-03SL (CW) device panel.
Choose brighter illumination for everyday activities or lower the level for a softer evening atmosphere. The CW controller’s specified dimming range is 1%–100% when used with a compatible LED strip. Zemismart
Simple On/Off Control
The dedicated power button provides a straightforward way to switch the connected LED strip on or off from the Homey device panel.
Warm-to-Cool White Lighting
The ZMZ-03SL (CW) is designed for compatible dual-white LED strips, with a specified color temperature adjustment range of 2700K–6500K. Zemismart
The Homey interface shown below provides white-light presets and a larger color temperature picker. Select a warmer tone for an evening setting, a neutral white for general lighting, or a cooler white to suit your workspace.
Choose the Controller for Your Installation
ZMZ-03SL (CW) — Adjustable White Lighting
Designed for 12V/24V constant-voltage CCT LED strips, the CW model combines brightness adjustment with warm-to-cool white control. It is the model featured in the Homey control screens above. Zemismart
ZMZ-03SL — RGB + Adjustable White Lighting
Designed for 12V/24V constant-voltage RGBCCT LED strips, the RGBCCT model combines RGB color channels with dedicated warm and cool white channels. Its product specifications include approximately 16 million colors, 2700K–6500K white color temperature adjustment, and 1%–100% brightness control. Zemismart
The Homey control screens in this post demonstrate the CW model. RGB controls and other RGBCCT-specific functions are not demonstrated here.
Before Setting Up
Choose the controller that matches your LED strip’s voltage and channel configuration. Both models use Zigbee; for operation through the Tuya Smart app, a compatible Tuya Zigbee hub is required. Zemismart
For Homey setup questions, please include your Homey model, controller model, and intended connection method when replying to this topic. This will help us address your specific installation without confusing different setups.
Official Product Information
ZMZ-03SL — RGBCCT LED Strip Controller
https://www.zemismart.com/products/zmz-03sl
ZMZ-03SL (CW) — CCT LED Strip Controller
https://www.zemismart.com/products/zmz-03slcw
We welcome your questions, installation experiences, and feedback on the lighting controls you would like to see next.
Thank you for your interest in Zemismart and for sharing your ideas with the Homey community.
