Zehnder Comfoconnect Homey API?
Subject: Zehnder Comfoconnect controlled by API in homey
Currently the most used way to connect to a Zehnder system is by doing a technical intervention by connecting on the 10volt switches of the machine.
However there is a comfoconnect plug that offers full acces to the device.
But I don’t see any use of it by Anthem
There is a published api :
Somebody even wrote a bridge for it in openhab:
It would open so many doors, it would not only be able to control the machine, but the sensors could also be used to automate other things.
The Zehnder ventilation systems has sensors for:
Indoor temperature and humidity
Outdoor temperature and humidity
It would be great if the API could be used instead of the 10volt aproach
Can someone help?
I appreciate the level of detail you have gone to, but there is a single thread were these request are kept.
Homey Community App Requests topic where you can request an app.
Please make sure you make the request with the provided template, to make sure all needed information is provided, including this information you have dug up.
This will be useful: GitHub - herrJones/node-comfoairq: Library to control a Zehnder Comfoair Q series of ventilation devices
Hey! I’ve made an app for Homey PRO to control ComfoAir Q units via ComfoConnect LAN C module. It’s available in the official homey store here: Zehnder ComfoConnect App for Homey | Homey
Thanks! But app crashes immediately after installation.
Hey, your app is supporting from Zehnder the next module:
  • ComfoConnect LAN C
What about Zehnder Multi Control for EVO:
Thanks and Br,
Benjamin
