Z-wave issue items turns on with out active flow
Lately items in the z-wave network turns it self on with out any flows has turn them on. I have Aeotec heavy duty that controll my vvb (water heater) heatit controll z-dim and z-water that controls z-temp2. Z-wather is the item that I installed latest, but every thing worked fine one month before every item seem to go on the same time with out a flow has activated them. Lights can go on in the night and heavy duty gives power to the heater when it is supposed to be off. In the homey app every item that is supposed to be off is the color gray and seem off, but the light is on in the room and heavy duty is using W and A.
Do any one have any ideas what I can do?
Install Flow Checker if you didn’t already.
  • Disable the zwave app(s) involved.
  • After a while, Flow Checker will report which flows are used with zwave devices.
  • This way, maybe you’ll discover flow(s) you might have overlooked.
But, as you say, if the device tiles are off / greyed out, a flow doesn’t look like being the cause.
What do the devices logs say?
Longpress a device tile, hit the icon at the bottom right.
Zwave devices can contol other zwave devices without Homey, but if that happens, the device tiles on Homey should just show their current On Off status…
I think you’d better start over with these zwave devices.
Reset them to defaults (if possible)
Remove them from Homey
Pair them again
Fix flows manually (there’s a “fix your flows” script, but I’m afraid you also “fix” an error back into your flows.
Also make sure there’s no signal issue.
And other broken, unused (This flow was startet…) flows. So it might be confusing.
If you long press on the device tile and switch to this menu…
…then all the flows are listed where the device performs an action, e.g. turns on/off. In my opinion, this should be enough to find relevant flows and deactivate them.
This function (association) must be configured manually. So it’s not possible for this function to be activated suddenly or accidentally.
But if you @Andre_Kleppe_Risvold have configured any associations, then remove them and test if the problems still occur.
Before you remove all devices and then add them again, I would suggest to check first if the devices may have problems with communication (Developer Tools → Z-Wave (3 points → Test)).
With the command Send Basic On/Off you can also test, if the devices switching on/off correctly.
I can’t really explain the behavior, but because it worked for a time and then suddenly these problems occurred, I could well imagine that a Z-Wave device is broken and/or interfering frequencies are there, e.g. due to a defective power supply.
True, but I assume the user can check things for himself. No tool app is understood right away, one has to read, try, test things out.
I can’t explain the whole app everytime I hint to a tool what is probably very useful.
And when the user doesn’t understand something, he can always ask, right?
:wink:
Hi @Andre_Kleppe_Risvold. Do you still have this issue? I am also having the same issue, and athom can’t find out what is causing the problem. I have also z-temp2 and z-water set up in direct association. I have one heatit z-relay and one fibaro plug that is turning themselves on randomly, but always at the same time. When I look at the log of the z water it seems to be turning the relays on/off randomly as well.
@Magnus_Engseth I have the same issue it seems. I was lucky enough to be logging the z-wave network when it happened and it seems like the z-water regulator is definitely turning on my relays and the lights connected to it. Have you gotten a solution from Athom? I’ve just sent over a copy of the log and hopefully they can figure out a fix.
@KnutHenrik I have been trying to catch logs for weeks, but have never managed to… Interesting to hear that you have some logs. Athom has left me on my own and said that I should just exclude and include units until I find out what is causing the issue. I have reached out to “Thermo floor” however (the producer of heatit) to see if they can help. I’ll update this thread if I find something interesting.
@Magnus_Engseth Have a look at my last post on the fibaro forum: [APP] Fibaro - Your home is your castle (by Athom) - #956 by KnutHenrik
Seems like z-water is sending a command to homey with data 255, which apparently the switches picks up and 255 turns on all the switches. I’ve tried changing the parameters on two of the switches in advanced settings to 254 just to see the effect, but none of the lights have come on yet. I also checked the group 1 associations for the z-water. Both mine are now at 1.1 for group 1.
@KnutHenrik I contacted Thermo Floor who develops the Heatit-products. They had received reports that the Z-temp2 devices randomly send out on/off commands to alle devices in the network. The problem has been fixed in a firmware update. Thermo-Floor sent my new thermostats with the latest firmware (1.2), and I returned my old thermostats. I have had no issues since may.
