Xiaomi Door/Window sensor version 2, Homey support?
Anybody knows if Homey supports this device?
Do you mean this one? (if not, please provide a link to the device you’re referring to)
If so, my guess is that it will require BLE capabilities that Homey lacks.
Completely off topic, but check dat link from @robertklep. Who puts a sensor on the cookie jar? :rofl:
Also, too bad Homey doesn’t support BLE. But on the other hand, I used Eve products (with Bluetooth) and they were bad. So just use Zigbee.
Homey does support BLE, it just lacks some important features that a lot of devices require.
So you consider putting a sensor on the toilet lid is normal?
Oh, then that is what it is! :wink: But you also need extenders to have this work properly if your house is anything bigger than a small living room.
@TedTolboom was that a toilet seat? OMG lol
That’s not even a really bad idea, together with a pressure sensor detecting of someone left the toilet, smart speaker yelling CLOSE DOWN THE LID…
yes sir, thats the one.
I guess no support for it then huh? Tough luck. Thanks for the reply tho! :slight_smile:
I bought same sensor “Mi Door and Window Sensor 2” recently ( Model: MCCGQ02HL ) and I found this page :slight_smile:
There is the link: https://mistore.se/products/mi-door-and-window-sensor-2?variant=41957728092389
So I guess the solution will be, buy a “Xiaomi Smart Home Hub 2” and bridge sensor to homey via the hub, am I right? Or there is another better solution?
Thanks in advance :slight_smile:
