I experience quite significant lags between withings sleep analyses trigger and its registration in homey (in all ways I try to use: directly from withings app, via ifttt with ifttt app, via ifttt with webhook)… this makes couple of my flows unusable, do you have any possible fix for that?
TIA
So it’s both IFTTT and the Homey app? The readings are probably delayed by the server in that case (or the app uses polling, which means that it only checks every few minutes)
This has been working properly (just instant status change) till around z week ago… I suspect either server issue on Withings side or homey webhook server… but I have not found any reasonable fix …
If IFTTT has the same issue like you mentioned, then the issue is probably on the Withings server. Maybe you should contact their support team, since both Homey and IFTTT are official integrations?
Possibly… I am trying to get things right on my side first, in last instance -.> their support as I think this would be the very low priority for them… I have actually measured the lag today → 2:30 min…
