[APP][Pro] Wireless Weather Sensors - Reads data from several brands of wireless weather sensors
Wireless Weather Sensor app for Homey.
Current version: 2.0.3
Test version: 2.5.2
Changes in version 2.5.0:
• Changed driver model, updated app settings UI
• Added support for Auriol HG05124A-DCF-TX (Auriol v2)
• Stricter timing to improve reception
• Removed Oregon Scientific v2.2, moved to OS v2 (sensors need re-pairing)
• Removed Labs, moved into Alecto v1
Changes in version 2.5.1:
• Added support for Alecto WS-1700
Changes in version 2.5.2:
• Fixed wind speed for Alecto, Cresta & Oregon Scientific
As there are quite some changes (under the hood), I would appreciate if people can help with testing to see that nothing is broken.
The test version can be used via Wireless Weather Sensors App for Homey | Homey
I’ve added my Alecto v1 sensor to the test app. But temperature and humidity are swapped.
{“temperature”:76.8,“humidity”:20,“lowbattery”:false}
Sensor is part of the Alecto ws-1700 set
@remcodk First of all, thanks for testing! Really appreciate this.
Couple of questions?
  1. Did this sensor work OK with the previous version of the app?
  2. Did you pair this sensor with a previous version of this app or with this version?
  3. Could you download statistics on a PC via <homey_ip>/api/app/com.weather-sensors/getStatistics/ and email the data to homey.powermax at gmail.com
Hello @nlrb, I also tested the sensor Auriol HG05124A today. Works perfectly. Thank you very much.
@lirand Great to hear, thanks for contributing & testing!
Test version has been updated to 2.5.1.
  1. I don’t know if it worked with the previous version, because I could not get it paired.
  2. No that did not work, but in the test app it showed up.
  3. I can not get it found again but made a dump anyway. Is it possible that I picked up a sensor from the neighbours?
{“alectov1”:{“signal”:“Alecto v1”,“enabled”:true,“stats”:{“total”:15818,“ok”:“3%”,“error”:“90%”,“invalid”:“7%”,“lengths”:{“36”:553},“payloads”:[{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:23.452Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:23.552Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:23.652Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:23.852Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:23.951Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:58.264Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:58.459Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:58.660Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:58.760Z”},{“data”:“0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-11T14:56:58.958Z”}],“debug”:["[15:56:23.552] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:23.651] Received payload for Alecto v1","[15:56:23.651] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:23.652] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:23.850] Received payload for Alecto v1","[15:56:23.851] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:23.852] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:23.950] Received payload for Alecto v1","[15:56:23.950] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:23.951] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:58.262] Received payload for Alecto v1","[15:56:58.263] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:58.264] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:58.458] Received payload for Alecto v1","[15:56:58.458] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:58.459] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:58.658] Received payload for Alecto v1","[15:56:58.659] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:58.660] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:58.759] Received payload for Alecto v1","[15:56:58.759] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:58.760] Error: CRC error for Alecto v1 data (12 vs 11)","[15:56:58.957] Received payload for Alecto v1","[15:56:58.957] 36 [0,1,0,1,0,1,0,0,1,1,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,1,0,0,0,0,1,1,1,1,0,1]","[15:56:58.958] Error: CRC error for Alecto v1 data (12 vs 11)"],“last”:{“id”:“42”,“data”:{“temperature”:76.9,“humidity”:24,“lowbattery”:true},“channel”:3,“protocol”:“alectov1”,“lastupdate”:“2020-01-11T13:14:53.486Z”}}},“alectov3”:{“signal”:“Alecto v3”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“auriol1”:{“signal”:“Auriol”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“auriol2”:{“signal”:“Auriol v2”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“cresta”:{“signal”:“Cresta / TFA”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“lacrosse1”:{“signal”:“La Crosse TX2/3”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“lacrosse2”:{“signal”:“La Crosse WS”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“oregonv2”:{“signal”:“Oregon Scientific v2”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“oregonv3”:{“signal”:“Oregon Scientific v3”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“tfa”:{“signal”:“TFA”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},“upm”:{“signal”:“UPM/Esic”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}}}
I updated the app version to 2.5.1 and now the sensor is discovered again. Also the temp and hum values are not swapped anymore!
Yes, looks like a sensor that was not supported before. What is the type number?
@nlrb, installed 2.5.1 and both my Ventus W 41 sensors (Alecto v1) seem to work ok.
Gr. Remco
@nlrb It is a WS-1700 sensor. Thanks for your effort.
Just installed the app and so far it works fine.
I’ve tested two weather stations:
  • TECHNISAT IMETEO 4 CE - not detected
  • Hama EWS-Trio - detected as Auriol protocol
Big thanks for this app!
@rzarajczyk Thanks for test. I don’t have the TECHNISAT IMETEO 4 CE myself and don’t know what protocol it uses.
Oh no problem with that - I just returned it to the shop :slight_smile:
Hello Ramón,
as i write you i connect all my weather 433 sensor with your app to Homey.
it is two independet thermo/hygrometer from different suplier, Anemometer/Thermohygrometer and Rain sensor. All is connectet with Alecto v1 protocol.
All therm/hygrometer running correct. Wind sensor but show me value that not corresponding with value on original display of weather statin, because i mean, is nice to have posibility multiple this value to earn real value of measure.
Value 2,2 km/h is about 10km/h on the original weather station.
Rain sensor i have still not checked for values.
All models if you interestet i can describe you in next comunication if you interestet.
This anemo combinatet with Thermohygro and separates Rainsensor is from Weinberger Gmbh according labeling. Thank You
@KarolG Thanks for letting me know! I checked and noticed that the value I report is in m/s, whilst Homey expects km/h. So the value should be multiplied by 3.6. But in your case that would give 7.92 km/h and not 10 km/h. Could that still be correct? I’ll update the value to be in km/h.
I’ve created https://github.com/nlrb/com.weather-sensors/issues/71 to fix it.
Hello Ramón, i try more precisely measure this multiplier than i write you result. I think too ths sensor us another unit of measure in protocol. Tahank You for support.
@KarolG Could you download statistics via <homey_ip>/api/app/com.weather-sensors/getStatistics/ and provide me some payloads?
Hello Ramón,
i canot send data as mean because i paste it simple
Karol
[{“signal”:“Alecto v1”,“enabled”:true,“stats”:{“total”:137774,“ok”:“77%”,“error”:“23%”,“invalid”:“0%”,“lengths”:{“35”:210,“36”:106091,“37”:102},“payloads”:[{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:true,“when”:“2020-01-19T11:14:52.758Z”},{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:true,“when”:“2020-01-19T11:14:52.847Z”},{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:true,“when”:“2020-01-19T11:14:52.947Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:06.322Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:06.452Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:06.581Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:06.712Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:06.971Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:07.101Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:true,“when”:“2020-01-19T11:15:07.231Z”}],“debug”:["[12:14:52.848] Sensor value has changed: false","[12:14:52.946] 36 [0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1]","[12:14:52.947] {\n ‘id’: ‘42’,\n ‘data’: {\n ‘temperature’: 4.9,\n ‘humidity’: 67,\n ‘lowbattery’: false\n },\n ‘channel’: 3\n}","[12:14:52.949] Sensor value has changed: false","[12:15:06.321] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.321] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:06.323] Sensor value has changed: false","[12:15:06.451] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.451] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:06.453] Sensor value has changed: false","[12:15:06.581] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.581] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:06.583] Sensor value has changed: false","[12:15:06.711] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.711] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:06.713] Sensor value has changed: false","[12:15:06.970] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.970] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:06.973] Sensor value has changed: false","[12:15:07.100] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:07.100] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:07.102] Sensor value has changed: false","[12:15:07.230] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:07.230] {\n ‘id’: ‘14’,\n ‘data’: {\n ‘raintotal’: 55,\n ‘lowbattery’: false\n }\n}","[12:15:07.232] Sensor value has changed: false"],“last”:{“id”:“14”,“data”:{“raintotal”:55,“lowbattery”:false},“protocol”:“alectov1”,“lastupdate”:“2020-01-19T11:15:07.231Z”}}},{“signal”:“Alecto v3”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“Auriol”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“Cresta / TFA”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“Labs”,“enabled”:true,“stats”:{“total”:88769,“ok”:“0%”,“error”:“100%”,“invalid”:“0%”,“lengths”:{“36”:2},“payloads”:[{“data”:“1,1,0,1,0,1,0,0,0,1,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,0,1”,“valid”:false,“when”:“2020-01-19T11:14:40.653Z”},{“data”:“1,1,0,1,0,1,0,0,0,1,1,0,1,1,1,0,0,1,0,1,1,0,1,0,0,0,0,0,0,0,0,0,0,1,1,0”,“valid”:false,“when”:“2020-01-19T11:14:40.849Z”},{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:false,“when”:“2020-01-19T11:14:52.259Z”},{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:false,“when”:“2020-01-19T11:14:52.460Z”},{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:false,“when”:“2020-01-19T11:14:52.763Z”},{“data”:“0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1”,“valid”:false,“when”:“2020-01-19T11:14:52.955Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:false,“when”:“2020-01-19T11:15:06.327Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:false,“when”:“2020-01-19T11:15:06.587Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:false,“when”:“2020-01-19T11:15:06.978Z”},{“data”:“0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0”,“valid”:false,“when”:“2020-01-19T11:15:07.235Z”}],“debug”:["[12:14:40.251] Error: CRC error for Labs data (9 vs 6)","[12:14:40.367] 36 [1,1,0,1,0,1,0,0,0,1,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,0,1]","[12:14:40.368] Error: CRC error for Labs data (4 vs 11)","[12:14:40.558] 36 [1,1,0,1,0,1,0,0,0,1,1,0,1,1,1,0,0,1,0,1,1,0,1,0,0,0,0,0,0,0,0,0,0,1,1,0]","[12:14:40.558] Error: CRC error for Labs data (9 vs 6)","[12:14:40.653] 36 [1,1,0,1,0,1,0,0,0,1,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,0,1]","[12:14:40.653] Error: CRC error for Labs data (4 vs 11)","[12:14:40.849] 36 [1,1,0,1,0,1,0,0,0,1,1,0,1,1,1,0,0,1,0,1,1,0,1,0,0,0,0,0,0,0,0,0,0,1,1,0]","[12:14:40.849] Error: CRC error for Labs data (9 vs 6)","[12:14:52.258] 36 [0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1]","[12:14:52.259] Error: CRC error for Labs data (1 vs 14)","[12:14:52.459] 36 [0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1]","[12:14:52.460] Error: CRC error for Labs data (1 vs 14)","[12:14:52.762] 36 [0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1]","[12:14:52.763] Error: CRC error for Labs data (1 vs 14)","[12:14:52.955] 36 [0,1,0,1,0,1,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,1,1,1]","[12:14:52.955] Error: CRC error for Labs data (1 vs 14)","[12:15:06.326] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.327] Error: CRC error for Labs data (0 vs 7)","[12:15:06.586] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.587] Error: CRC error for Labs data (0 vs 7)","[12:15:06.975] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:06.978] Error: CRC error for Labs data (0 vs 7)","[12:15:07.235] 36 [0,1,1,1,0,0,0,0,0,1,1,0,1,1,0,0,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,1,0]","[12:15:07.235] Error: CRC error for Labs data (0 vs 7)"],“last”:{“name”:“BL999”,“id”:“44”,“channel”:1,“data”:{“temperature”:0.1,“humidity”:-155,“lowbattery”:false},“protocol”:“labs”,“lastupdate”:“2020-01-19T02:50:55.493Z”}}},{“signal”:“La Crosse TX2/3”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“La Crosse WS”,“enabled”:true,“stats”:{“total”:1,“ok”:“0%”,“error”:“100%”,“invalid”:“0%”,“lengths”:{},“payloads”:[{“data”:“0,0,0,1,1,1,0,1,1,1,0,1,0,0,0,1,0,0,0,1,1,0,0,0,0,0,1,0,1,1,0,1,0,1,1,0,1,1,1,0,1,1,0,0,1,1,1,1,0,1,1,0,1,1,1,0,0,1,1,1,1,1,1,0,1”,“valid”:false,“when”:“2020-01-18T14:58:02.878Z”}],“debug”:["[15:58:02.877] 65 [0,0,0,1,1,1,0,1,1,1,0,1,0,0,0,1,0,0,0,1,1,0,0,0,0,0,1,0,1,1,0,1,0,1,1,0,1,1,1,0,1,1,0,0,1,1,1,1,0,1,1,0,1,1,1,0,0,1,1,1,1,1,1,0,1]","[15:58:02.878] Error: Not a known message type of length 65"]}},{“signal”:“Oregon Scientific v2.1”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“Oregon Scientific v2.2”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“Oregon Scientific v3”,“enabled”:true,“stats”:{“total”:0,“ok”:“0%”,“error”:“0%”,“invalid”:“0%”,“lengths”:{},“payloads”:,“debug”:}},{“signal”:“UPM/Esic”,“enabled”:true,“stats”:{“total”:1187,“ok”:“0%”,“error”:“100%”,“invalid”:“0%”,“lengths”:{},“payloads”:[{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T08:49:24.363Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T08:50:23.521Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T08:51:22.687Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T08:54:22.306Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T08:55:21.510Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T08:56:20.728Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T09:04:14.722Z”},{“data”:“2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T09:23:02.113Z”},{“data”:“2,2,2,2,1,1,1,1,1,1,2,2,2,1,1,1,1,1”,“valid”:false,“when”:“2020-01-19T09:24:04.834Z”},{“data”:“0,0,0,2,1,0,2,3,1,2,3,3,3,3,3,3,3,3,3”,“valid”:false,“when”:“2020-01-19T09:39:32.296Z”}],“debug”:["[09:50:23.521] Error: Not a valid message","[09:51:22.685] 18 [2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1]","[09:51:22.685] New bitstream 0000000011110011000011111 25","[09:51:22.687] Error: Not a valid message","[09:54:22.305] 18 [2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1]","[09:54:22.305] New bitstream 0000000011110011000011111 25","[09:54:22.306] Error: Not a valid message","[09:55:21.508] 18 [2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1]","[09:55:21.509] New bitstream 0000000011110011000011111 25","[09:55:21.510] Error: Not a valid message","[09:56:20.727] 18 [2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1]","[09:56:20.727] New bitstream 0000000011110011000011111 25","[09:56:20.728] Error: Not a valid message","[10:04:14.721] 18 [2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1]","[10:04:14.722] New bitstream 0000000011110011000011111 25","[10:04:14.722] Error: Not a valid message","[10:23:02.112] 18 [2,2,2,2,1,1,1,1,2,1,1,2,2,1,1,1,1,1]","[10:23:02.112] New bitstream 0000000011110011000011111 25","[10:23:02.113] Error: Not a valid message","[10:24:04.832] 18 [2,2,2,2,1,1,1,1,1,1,2,2,2,1,1,1,1,1]","[10:24:04.833] New bitstream 0000000011111100000011111 25","[10:24:04.834] Error: Not a valid message","[10:39:32.294] 19 [0,0,0,2,1,0,2,3,1,2,3,3,3,3,3,3,3,3,3]","[10:39:32.295] New bitstream 00000100010100101010101010101010 32","[10:39:32.296] Error: Not a valid message"]}}]
ne 19. 1. 2020 o 12:17 Karol Gursky karol.gursky@gmail.com napísal(a):
Thanks @KarolG. Unfortunately these payloads are from a temperature sensor and the rain sensor. There is no data in there from the wind sensor.
