Why does Homey Pro query DNS (internal) for SOA (source of authority) of domain "local"
Dear all,
I love Homey, let’s start with this first!
But I also love my pi-hole :slight_smile:
I see Homey asking my dns, for about 2 times a minute, who the SOA is for domain “local”
And this is filling up my query logs.
So I have these questions:
Is there a setting in Homey, were I gave it a domain name of “local”?
Is this a setting of Homey that can be changed or is it hard-coded?
Why is my Homey doing this?
Hope someone can help me, finding the answers to my questions.
Thanks all, for your time and effort,
With kind regards,
Not specifically, but Homey will present itself on the local network as “Homey-XXX.local” to allow for autodiscovery.
It’s hardcoded.
My guess is that it’s an underlying piece of system software running on Homey, like the Avahi/mDNS daemon. It’s fairly common for OS’s to do regular SOA probes (there’s probably a good reason for it), but it’s not something you can disable.
Not sure if I’m supposed to do this - but anyhow:
I have noticed this with dnsmasq as well - and it does this a lot - every few seconds (see below)!
The homey pro device as ip 192.168.230.210.
If I let dnsmasq forward these to 127.0.0.1:5353 (i.e. avahi)) then nothing happens - other then repeating the same request over-and-over.
Similar when forwarding these to 127.0.0.1 (i.e. dnsmasq) then dnsmasq responds with nxdomain - after which the request is repeated.
If I let dnsmasq be the authorative server for the local-domain by creating a soa config which points to 127.0.0.1 (i.e. dnsmasq) it starts asking for A and AAAA records of a gateway, appending all domains homey pro is aware of (i.e. local and domotica.lan). This is then also repeated over-and-over.
Jun 15 19:41:12 dnsmasq[24793]: query[SOA] local from 192.168.230.210
Jun 15 19:41:12 dnsmasq[24793]: auth local is <SOA>
Jun 15 19:41:12 dnsmasq[24793]: query[A] gateway-2077-6072-7122.local from 192.168.230.210
Jun 15 19:41:12 dnsmasq[24793]: auth gateway-2077-6072-7122.local is NXDOMAIN
Jun 15 19:41:12 dnsmasq[24793]: query[AAAA] gateway-2077-6072-7122.local from 192.168.230.210
Jun 15 19:41:12 dnsmasq[24793]: query[A] gateway-2077-6072-7122.local.domotica.lan from 192.168.230.210
Jun 15 19:41:12 dnsmasq[24793]: cached gateway-2077-6072-7122.local.domotica.lan is NXDOMAIN
Jun 15 19:41:12 dnsmasq[24793]: query[AAAA] gateway-2077-6072-7122.local.domotica.lan from 192.168.230.210
Jun 15 18:00:05 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:00:14 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:00:22 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:00:30 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:00:38 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:00:46 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:00:54 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:03 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:11 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:19 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:28 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:36 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:44 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:01:52 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:01 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:09 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:17 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:25 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:33 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:41 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:50 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:02:58 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:06 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:14 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:22 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:31 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:39 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:47 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:03:56 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:04 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:12 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:20 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:29 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:37 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:45 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:04:54 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:02 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:10 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:18 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:26 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:35 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:43 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:05:51 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:00 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:08 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:16 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:24 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:32 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:40 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:49 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:06:57 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:05 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:14 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:22 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:30 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:38 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:47 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:07:55 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:03 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:12 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:20 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:28 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:37 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:45 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:08:53 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:01 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:09 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:17 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:25 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:34 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:42 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:50 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:09:58 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:10:06 dnsmasq[16096]: query[SOA] local from 192.168.230.210
Jun 15 18:10:15 dnsmasq[16096]: query[SOA] local from 192.168.230.210
